Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Mon Sep 29, 2014 9:52 am Post subject: Big ratio rockers |
Yesteryear there were more rockers available in the 1.5 to 1.6 range. The Sig Ersons are gone, Pauter made their 1.6 ford rockers and berg had the 1.54 and that's all that come to mind. Sig also made a rare 1.65 rocker.
I would like to get a set of big ratio set of rockers that are reasonably priced, any ideas out there? Are some that are available now bigger than advertised?
Dan |
mark tucker Samba Member
Posted: Mon Sep 29, 2014 2:03 pm Post subject: |
they come in all sorts of raitos. I have some 1.5,1.6,1.7,1.9,2.1. the trick is to make sure everything gets along well togeather.as for the rocker being for a vw.....not nessary.it is nice when things just bolt on with little or no alteration, but whats the fun in that? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Mon Sep 29, 2014 2:06 pm Post subject: |
Berg is now making their 1.45 ratio rockers again, No other sizes are listed. http://www.thesamba.com/vw/classifieds/detail.php?id=1686098 _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Mon Sep 29, 2014 4:07 pm Post subject: |
Yes already seen the new bergs but I think they are not made by berg and not in my budget. I am thinking of just going with some sigs out of the samba classifieds. Anybody know what the actual ratio is on the sigs verses the advertised.
Dan |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
Posted: Mon Sep 29, 2014 5:48 pm Post subject: |
Didn't i sell you a set dan ?? |
Posted: Mon Sep 29, 2014 6:15 pm Post subject: |
raul arrese wrote: |
Yes you did and I still have them. They are autocraft 1.4 but they measure out to about 1.36 and with the Web 163+6 ([email protected]) cam should work real well, BUT I am thinking about going to a Web 86a+3 ([email protected]) with a 1.5 or bigger arm which I think would be a more durable in the long term.
I guess I am a little anal and torn on which way to go. Both setups will have close to the same lift.
The engine will be a 2160 with my 44X37 heads ported by me.
Dan |
woodsbuggy Samba Member
Joined: December 15, 2007 Posts: 210 Location: NE Indiana
Posted: Mon Sep 29, 2014 6:26 pm Post subject: |
I have owned a couple different sets of the Sig rockers and pushrods but I was not impressed with the quality so I did not run them. Just my opinion.
Good Luck
Kenric _________________ The empty can rattles the most! |
Posted: Mon Sep 29, 2014 6:34 pm Post subject: |
woodsbuggy wrote: |
Good Luck
Kenric |
I have used them before without any trouble. You just have make sure they get enough oil. But you are right they are not top shelf.
Wish I still had my bergs. Sold them back in 1996 when I got out of VW's when I got the Vtec bug. I am done with front drivers.
Dan |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
GTV Samba Member
Posted: Mon Sep 29, 2014 9:11 pm Post subject: |
I bet it's the same rocker sold by other companies, just "POTL". _________________ EMPI Power Rules! |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Mon Sep 29, 2014 9:36 pm Post subject: |
Doubt it. If it has JPM's name on it, I'm sure it's exclusive to them.
*Edit: I read the description. Those are theirs only, but they only work with their MS heads. |
Posted: Tue Sep 30, 2014 5:46 am Post subject: |
Dan Ruddock wrote: |
Dan |
Yep , that's wht im using right now , 86a with pauter 1.5 |
neil68 Samba Member
Posted: Tue Sep 30, 2014 8:07 am Post subject: JPM ratio rockers |
bugguy1967 wrote: |
IIRC, you can use JPM ratio rockers on other heads, as their shafts are drilled for the two stock stud holes (just remove the other three blocks). You can also pull the rockers and use on some of the other HD shafts (not all). _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Tue Sep 30, 2014 10:24 am Post subject: |
I have 2 sets of the old china 1.4's with needel bearings that check out at 1.56, Ill do something with them someday.... I ran 1 set on a fk8 for a short time,ran well but prings were right at the limit....more like a little past the limit,right to coil bind so it was a short time then back to the lower ratio before it killed somethen.
whatever raito you choose be sure the spring can handle it in real time checks, not math check. checl keeper clearance too. |
Posted: Tue Sep 30, 2014 10:59 am Post subject: |
I might be interested in a set of those. What head casting gave you that big number? My heads are 040. I will be running a cam with .335 cam lift so things won't be at the limit but I will still check things.
Dan |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Tue Sep 30, 2014 1:15 pm Post subject: |
Dan, What is the purpose of the build? Short term life? Seems like you are asking for more guide/valve sideload issues the bigger you go. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
doug80 Samba Member
Joined: September 26, 2014 Posts: 22 Location: Ridgefield
Posted: Tue Sep 30, 2014 1:52 pm Post subject: |
Are you guys sold on the Ratio/Cam set-up ? I talked to a prominate engine builder who claims he did extensive testing with ratio's on a Dino machine. the motor size was a 2276 and says he just could not produce the pony's, like other motors with 1:1 to 1. Now he don't even care for the 2276 says geometry messed up. I've seen the guy crank out some really impressive off-road motors.
But of course I just happen to have a 2276 W/ 1:4 to 1 Berg Rockers
I am having a problem with the serious lack of bottom end power |
Posted: Tue Sep 30, 2014 4:49 pm Post subject: |
yamaducci wrote: |
Dan, What is the purpose of the build? Short term life? Seems like you are asking for more guide/valve sideload issues the bigger you go. |
Too big what? rocker ratio? lift? or what? I would rather get my lift from the rocker than the cam. Big lift with stock or ratio rockers will both be harder on guides. The car will be a daily driver with a backup long block for when the primary needs servicing. If I want to take it for a long trip I can always bolt on some smaller ratio rockers.
All the top drag racers use ratio rockers and if someone is making more power with a stock rocker setup something is wrong with the rest of the engine. Long live the VZ series.
Dan |
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Tue Sep 30, 2014 4:59 pm Post subject: |
There's only one type of rocker I use and it's Pauter
The advantage of going to an higher ratio rocker is you relieve a lot of the stress at the lifter (smaller lift there and at the cam) -- -- just go to the dual taper push rods and you're golden _________________ Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch |
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Tue Sep 30, 2014 7:34 pm Post subject: |
I was digging around my old parts bin the other day and found a set of the Pauter 1.6 Ford Rocker from back in the early 1970's. I remember talking to Don about 18 years ago and showing him the rockers, he just laughed and said they didn't work out as well as they had hoped. I only use their Roller Rocker in my personal engine now. |
