1979westie Samba Member
Joined: January 08, 2004 Posts: 1093 Location: Flying this P-27 bomber
Posted: Mon Sep 29, 2014 12:31 pm Post subject: 1979 head/heaterbox/exhaust options |
Well, it's definitely time. My original factory heater boxes have finally rusted through where the pipes weld to the flanges and cannot be repaired. Also, my exhaust crossover pipe has rusted through as well after 11 years.
I have some decisions to make. Apparently they have finally started making 1979 only heater boxes. However, I cannot find the crossover pipe that the muffler attaches to anymore. In addition, as of my last compression test a couple years ago with valves all zeroed out my readings were as follows:
1-110
2-123
3-105
4-115
So compression is falling, esp. on #3. If I am going to do the exhaust I am dropping the engine to do it, and I think since the engine itself sans heads is in proper shape (doesn't burn oil, oil pressure good, proper crankshaft end play) I figure some rebuilt heads would do a world of good.
So I'd like to find the best and most cost effective method. I've heard 2.0 heads up to 78 will fit a '79, and then you can install the cheaper -78 heater boxes and exhaust and be just fine. Or if I can find a '79 crossover pipe I can use rebuilt '79 heads and buy the more expensive '79 only heater boxes. Anything I am missing here? Also, anyone have experience with the rebuilt heads you'd find on say Bus Depot? They say they have improved valve seats designed better than originals. Looking forward to any advice or experiences.
Been a long time since I've kicked around here! My old Victorian house took over my time and the bus has become the Home Depot Runner! _________________ Your car may do 0-60 in under 5 seconds, but can it sleep 4 and cook a meal?
1979 Deluxe Campmobile (quickly rusting away)
33K miles when bought, now at 61K
Proud Member #2 SBS (Stock Bus Society) |
Randy in Maine Samba Member
Posted: Mon Sep 29, 2014 1:05 pm Post subject: |
Hey there Eric!
Are you a 199 Federal set up?
If so, just find some decent 79 heaterboxes and use this from BD...
http://www.busdepot.com/071251053ek
If you are a 1979 CA set up, send me a PM. |
airkooledchris Samba Member
Posted: Mon Sep 29, 2014 2:46 pm Post subject: |
If you don't have to smog, then you have a lot of options.
Ive had a few 79's now, but fortunately didn't need both heater boxes at once where I ever considered switching to oval port heads.
When I needed a square port heater box, I went to Chris at Busted Bus. He had various options depending on what level of quality I was after. On one of the 2 busses I picked up a practically NOS drivers side heater box, but for the other I grabbed one that just needed a little hole patched up (wasn't a hole from rust) for a little less coin.
I know both will outlast brand new aftermarket heaterboxes, and cost less.
The exhaust that Randy posted is likely the best unit for this setup, again - if you don't need to smog. |
Posted: Mon Sep 29, 2014 3:49 pm Post subject: |
'79 heater boxes are a bit hard to find, but when you do the price is often right as few need or want them. Picked up a nice clean set last winter at a show for all of $10. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Mon Sep 29, 2014 5:05 pm Post subject: |
Oval port heat exchangers (pre '79) can easily be modified to fit a square port head by just cutting the 'extension' off the flange and filing them flat.
Then you can use the '72-'74 muffler. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
obx71super Samba Member
Joined: December 16, 2012 Posts: 340 Location: Outer Banks NC
Posted: Tue Sep 30, 2014 2:58 pm Post subject: |
Ahh I like the cut EM off and file EM flat approach. I've got some old square ports I didn't know what to do with! _________________ 71 super auto stick basically original minus a couple resprays
73 Westy automatic with a 2 liter gex, soon to be a 1.8 liter Headflow masters
Newest Addition!! Solid straight 74 thing totally disassembled!! YEEEWWWW |
Posted: Tue Sep 30, 2014 2:59 pm Post subject: |
Oops I'm a dummy that was vice versa lol _________________ 71 super auto stick basically original minus a couple resprays
my59 Samba Member
Joined: August 13, 2003 Posts: 3790 Location: connecting the dots
Posted: Tue Sep 30, 2014 3:44 pm Post subject: |
Soon after getting the 79 I ended up putting another engine in; a 78 that had a new exhaust. When I needed to do the heads I shopped long and hard on redoing the 79 Sq port heads as the 79 heater boxes were in poor shape and the exhaust not much better. The whole package cost put me toward a set of oval port heads and keeping the Oval port heater boxes and muffler.
I went with the Oval port items as easier to get and since it is a sunroof transporter with a west interior originality was less important. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Tue Sep 30, 2014 6:58 pm Post subject: |
Well then,
First, Hey Randy! I was just up in Portland with the bus last week! Fine little city, that. Yup, it's a federal engine.
So my main concern is that in NJ all our state inspection does anymore is test emissions. 1979 came with a catalytic converter, which I have. I'm worried if I switch to that other exhaust you linked that I may no longer pass without the catalyst. Does seem like a good option, although I just put a brand new muffler and tailpipe on last fall. I guess I could always sell it here.
I have no issue looking for used heat exchangers...rather have OE than Dansk anyway as long as they are pretty clean. But the big question that no one has yet touched on are the heads. Any experience with rebuilt heads? and 2.0 heads up to '78 will be a direct fit to a '79, right? No engine tin differences?
Thanks for the replies so far! _________________ Your car may do 0-60 in under 5 seconds, but can it sleep 4 and cook a meal?
mtcamper Samba Member
Posted: Tue Sep 30, 2014 7:39 pm Post subject: |
I cannot speak on the heads, but if you go oval port there could be engine tin differences. If you go with the 78 style heat exchangers you would have to use the tin from I think a 75-78 bus. If you go with 74 style heat exchangers you should be able to use the tin you have now. I have the same year westy as you and swapped over to another motor with oval ports. My opinion now would be to keep it original. Swapping stuff around I found myself chasing various parts around when if I kept it original I already had all the parts... Plus now when I look at my old square port heads and heat exchangers I realize how much more surface area is on the exhaust manifold area that mates to the head. Its got to make them easier to seal at the head, and less manifold to head leaks I would think. |
my59 Samba Member
Posted: Wed Oct 01, 2014 4:53 am Post subject: |
I spent last spring redoing the original 79 engine, using oval port heads and the 78 exhaust with the cat. The tins used were a combination of best condition pieces of what I had. The one thing I noticed different was the alternator bracket end of the 79 was not a straight bolt on to the exhaust; I had to fab an extra bit to make it work. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Posted: Wed Oct 01, 2014 9:04 am Post subject: |
I have used the 72-74 style setup without the factory crossover pipe. If you get one of those bugpack/empi/thunderbird extractors you can put a CAT in it with a short bodied muffler and still fit it under the rear bumper:
This one was hooked up to the O2 sensor as well, but if yours is federal you won't have to worry about it. You can use the CAT you have now. The extractor is less than $100 by itself (or much less if you can get it used.)
I cobbled this one together with spare bits around the garage and $40 to my local welder. |
