Wetstuff Samba Member
Joined: September 23, 2010 Posts: 700 Location: Maryland
Posted: Mon Sep 29, 2014 2:44 pm Post subject: Steering wheel/column dilemma... |
This is the style column I have..
It has a 14" Grant style wheel mounted on it which has a depth of 4" from nut-to-face of wheel. I recently (finally) found an adaptor for an orphan wheel I got two years ago...
Luckily, the new wheel is not a 'dishy' as the Grant ..and the diameter is the same, so I dodged a bullet there..
The question: should I change out the column to another year where the head of the column might not contrast so much with the bigass aluminum boss the new wheel bolts to..? Or is there such? Appreciate any thoughts.
Jim _________________ Manx #2614 |
WD-40 Samba Member
Posted: Sun Oct 19, 2014 4:50 pm Post subject: |
I would think a quick coat of silver spray paint on the top black part of the existing column would do the trick?
An earlier column isn't going to do anything but make the big polished adapter look even bigger and more out of place. "un-polishing" the adapter might also help draw less attention to it. _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
jsturtlebuggy Samba Member
Posted: Sun Oct 19, 2014 9:26 pm Post subject: |
Either late or early column is going to be same diameter where turn signal housing is. Having a locking column can be a good thing some times. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Mon Oct 20, 2014 5:17 am Post subject: |
Thanks guys, That wheel boss would be probably the brightest thing on the buggy. The idea of 'un-polishing' is probably what I will do..
Chuck it to spin and see if I can get a 3M pad, or similar, to make it more look like the spokes in the wheel. Thanks. I needed that kickstart.
TC/TeamEvil Samba Member
Posted: Thu Oct 23, 2014 6:19 pm Post subject: |
This is what I did with the column that was meant for my Berry Mini-T.
Went with a different idea, but not because of any problems with the function and look of the column head/directional.
Something like this might work for you as well . . .
If you like the look, but don't want to bother making your own version, I planning on putting this up for sale in The Samba Classified over the weekend. |
