Weezle Samba Member
Joined: February 07, 2014 Posts: 685 Location: ORLANDO
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51124 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Sep 30, 2014 6:19 pm Post subject: |
Anti sieze is fine and won't cause issues if torqued correctly, just don't drown them, a thin smear is all that's needed. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Weezle Samba Member
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21512 Location: Oklahoma City
Posted: Tue Sep 30, 2014 7:43 pm Post subject: |
busdaddy wrote: |
Anti sieze is fine and won't cause issues if torqued correctly, just don't drown them, a thin smear is all that's needed. |
X2.....brush it on, wipe it off. Thin, thin...just enough to color it. Use good anti-sieze. If you are working with steel bolts stay with the mixed anti-sieze like Henkel/felpro C5-A. The aluminum Permatex is primarily made for aluminum....its a bit more slippery.
There are well over 50 brands out there. Stay with top names.
Anti-sieze is not a lubricant per-se. If its made correctly its a collection of metal, silica etc whose sole purpose is to prevent galling. There should be only enough actual oil in it to make a paste for application. Its the metal flakes you want. Ray |
Weezle Samba Member
Posted: Wed Oct 01, 2014 7:55 am Post subject: |
raygreenwood wrote: |
busdaddy wrote: |
Ray thanks for reply. I have a print out of all your FI tune up stuff such as for decel valve et. al. Anyway here is the stuff I have:
http://www.amazon.com/Permatex-80078-Anti-Seize-Lu...atex+80078
it has aluminum, copper and graphite _________________ I got a fever, and the only prescription is more beetles!
http://www.thesamba.com/vw/forum/viewtopic.php?t=604918&postdays=0&postorder=asc&start=0
https://www.thesamba.com/vw/forum/viewtopic.php?t=759868&highlight= |
Posted: Wed Oct 01, 2014 10:01 am Post subject: |
There is nothing wrong with that...buts its main ingredient is aluminum. Use it very sparingly. Wipe the brush in the lid off so it just dusts/colors the bolt surface. That is one of the more slippery anti-seize compounds. Its got a lot of juice or oil in it but it works just fine.
Ray |
Weezle Samba Member
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
Posted: Thu Oct 02, 2014 8:57 am Post subject: |
Ray |
I use that and I usually lightly coat the bolt in it then sort of dab it off with a towel to remove the excess. It leaves the material in the threads but it doesn't sploosh everywhere on install. _________________ How to Post Photos
Posted: Thu Oct 02, 2014 4:34 pm Post subject: |
EverettB wrote: |
Ray |
I use that and I usually lightly coat the bolt in it then sort of dab it off with a towel to remove the excess. It leaves the material in the threads but it doesn't sploosh everywhere on install. |
X2
Ray |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Wed Oct 08, 2014 4:18 pm Post subject: |
I apply a little bit to one screw, then use the next screw to spread it around. That way only half is left on the first one. _________________
Randall Samba Member
Joined: October 03, 2004 Posts: 1403 Location: Orange County, Alta California, El Norte
Posted: Wed Oct 15, 2014 7:09 pm Post subject: Re: Anti-seize on suspension bolts |
Weezle wrote: |
Is it Ill advised to use anti-seize on suspension bolts, tranny and engine mount bolts? These things can be murder to remove. |
I found out the hard way what happens when a shock absorber bolt gets rusted inside a shock tower in one of the front wheel wells. In my case, the M12 bolt broke off right where it entered the tower. I had to drill the bolt out and buy a thread insert kit. In an environment where water is thrown around by the tire, anti-seize or a lubricant like silicone spray would have prevented that from happening. |
Posted: Wed Oct 15, 2014 10:34 pm Post subject: Re: Anti-seize on suspension bolts |
Randall wrote: |
Weezle wrote: |
Over long term.....silicone spray will not help at all. It washes off and/or dries out.. The reasom anti-seize works has nothing to do with the small amount of lught oil used to turn it into a paste.
That oul goes away quickly as well. It is the soft metal flakes and silica that are the filler (actually the main ingredient). They prevent perfect/total metal to metal contact and t b e metal flakes themselves oxidize over time. This metal flake layer prevents galling on initial torque and the metal oxide over the long haul prevents rust and galvanic action from welding the two fasteners together. Ray |
Posted: Wed Oct 15, 2014 11:10 pm Post subject: |
This calls for a celebration, Ray. You made your 6000th post.
I've got you beat when it comes to uploading photos; I have 12 more than you do. |
Posted: Thu Oct 16, 2014 12:15 pm Post subject: |
Randall wrote: |
Cool! So now I have a reason for drinking last night!
Yes....I upload few photos....but that may, change
Ray |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Mon Nov 03, 2014 6:44 pm Post subject: |
Antiseize eventually evaporates away. It works really well in a non highly exposed environments like a spark plug or lug nut that is serviced every couple of years. On suspension fasters it would only work good on a non daily driver. If the fastener is gong to be on for a long time; over five years, and it is practical ,blue loctite is better. Automakers use a sealer like product that they 'paint' the threads down the length on one side of the bolt that works like loctite. I see the same thing done on pipe fittings. The loctite is not used to 'lock' the fastener but it does not evaporate in 5 years and stays between the threads. Something like pan bolts ,use blue loctite.
I'm also using castle 'torque master' _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Mon Nov 03, 2014 7:26 pm Post subject: |
theKbStockpiler wrote: |
I'm also using castle 'torque master' |
Anti, sieze is supposed to evaporate. The oil in it has nothing to do with its anti-sieze properties. Its the soft metallic and silica components that are the anti-seize part.
The metal, components will oxidize with age and become powdery and black. As long as there is powdery residue you are still fine. Only when it becomes a tight thin black coating does it lose its anti-seize properties.
You have to remember that anti-seize is, not supposed to be a lubricant like and oil. Its not supposed to make things slippery. Its simply designed to prevent galling of similar alloys under torque. Ray |
mark tucker Samba Member
Posted: Tue Nov 04, 2014 12:10 am Post subject: |
the only down side to antiseezzee is it is going to be everywhere,even if you just do a little on the wifes honda it will be all over your vw and hear clothes. so be fair warned, that stuff has a mind of it's own. |
Posted: Tue Nov 04, 2014 7:04 am Post subject: |
mark tucker wrote: |
One of the first things I learned!
In high, school.....working on my first VW....my Dad taught me about using anti-seize.
But.....my Mom taught me about cleaning it up.....after I tracked it into the house.
Anti-seize is amazing stuff ......causes bolts and fasteners not to seize....and causes screaming in women!
Ray |
Posted: Tue Nov 04, 2014 10:25 am Post subject: |
But.....my Mom taught me about cleaning it up.....after I tracked it into the house. |
Damn, that stuff is nasty to clean off hands, I'd hate to be scrubbing it out of carpet. _________________ How to Post Photos
Posted: Tue Nov 04, 2014 11:09 am Post subject: |
EverettB wrote: |
Damn, that stuff is nasty to clean off hands, I'd hate to be scrubbing it out of carpet. |
I was lucky. It was brand new carpet.....and it was just at the top fringe off the side of my shoe.
Dad taught me another one.....he shaved a very thin layer off the top with a razor blade along with the anti-sieze.
Ray |
