Oldfart Samba Member
Joined: March 09, 2008 Posts: 187 Location: Strayliya
Posted: Wed Oct 01, 2014 1:33 am Post subject: 25/36HP |
What parts fit from 25HP to a 36HP? I have a 25 with a corroded crankcase. Was the 383 distributor fitted to a 36? Is the mechanical advance enough for a 36? Is the oil cooler the same? |
Posted: Sun Oct 05, 2014 6:01 pm Post subject: |
244 views and nobodies got any ideas? |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Sun Oct 05, 2014 10:07 pm Post subject: |
Iīm not an engine specialist but I would say:
The Cylinders donīt fit.
That causes the pistons, heads and the intake manifold will not fit as well.
Anything else could be used in/on both cases. _________________ Master of my domain! |
Posted: Mon Oct 06, 2014 4:39 am Post subject: |
Thanks |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76909 Location: Sneaking up behind you
Posted: Mon Oct 06, 2014 4:41 am Post subject: Re: 25/36HP |
Oldfart wrote: |
Was the 383 distributor fitted to a 36? Is the mechanical advance enough for a 36? |
The 383 has a totally different curve than the VJ4BR8 and VJU4BR8 fitted to the 36hp engine. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Oct 06, 2014 2:41 pm Post subject: Re: 25/36HP |
Glenn wrote: |
Oldfart wrote: |
The 383 has a totally different curve than the VJ4BR8 and VJU4BR8 fitted to the 36hp engine. |
Of course an engine in its original combination will run best.
But you could change them and it still runs. _________________ Master of my domain! |
Posted: Tue Oct 07, 2014 4:05 am Post subject: Re: 25/36HP |
usariemen wrote: |
Glenn wrote: |
Oldfart wrote: |
But you could change them and it still runs. |
So how is the advance curve in 25HP dissy different? Does it advance quicker and would be detrimental to a 36 HP? |
Posted: Tue Oct 07, 2014 10:05 pm Post subject: Re: 25/36HP |
Oldfart wrote: |
I used a 383 in an oval for years.
It ran and there was not a big difference noticed by me.
So that would be your smallest problem. _________________ Master of my domain! |
Posted: Tue Oct 07, 2014 11:31 pm Post subject: |
Bewdy, I like the neatness of the wires going out the back. |
