rrcade Samba Member
Joined: May 29, 2010 Posts: 735 Location: WI 1962 Bug 2276
Posted: Wed Oct 01, 2014 7:23 pm Post subject: Erco zero offset with front disc brakes |
I've read some Old posts where people have got these to work without spacers. Is anyone currently running wide 5 zero offset ercos in the front with disc brakes on a link pin front end? If so which disc setup are you running? I'm hoping to have drop spindles as well without spacers. Is this possible?
Thanks |
rrcade Samba Member
Posted: Sat Oct 04, 2014 6:37 am Post subject: |
OK, lets try this......evidently CMS is working on Zero offsets for the front that will clear all disc brakes, anyone know anything about this? |
MarvinNash Samba Member
Joined: November 27, 2011 Posts: 44 Location: Northern California
Posted: Tue Dec 16, 2014 6:13 pm Post subject: |
Airkewld bad series stage 3 brakes up front. Had to grind the caliper about 1mm.
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3152 Location: Goodyear, AZ USA
rrcade Samba Member
Posted: Thu Jan 22, 2015 10:15 pm Post subject: |
MarvinNash wrote: |
What else you got going on in the front? Drop spindles, narrowed?, adjusters,etc? I like your stance I'm trying to figure out what route I want to go in the front right now |
VeloMikey Samba Member
Posted: Wed Feb 04, 2015 11:38 am Post subject: |
rrcade wrote: |
Here you go... $239 each.
_________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
rrcade Samba Member
Posted: Wed Feb 04, 2015 6:57 pm Post subject: |
Of course they come out after I buy a set of Ercos, the Hell with it I'm gonna put drop spindles on and run drums up front seeing how nobody in the whole world is running ercos with disc brakes and can tell me which disc kit fits.
Someday I'll upgrade and probably get these rims, I'd love to see a pic of them on a car. |
vdub8 Samba Member
Joined: February 24, 2007 Posts: 125 Location: SLC, UT
Posted: Wed Feb 04, 2015 9:21 pm Post subject: |
I'm running ERCOs and Airkewld front disc. I chose to run spacers rather than modify calipers, etc. The caliper had basically no clearance and the brake pad retaining pin interference was at least .25".
_________________ My 67 build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=448654 |
