skip s Samba Member
Posted: Thu Oct 02, 2014 12:40 pm Post subject: How to identify Thing spindles |
I am going to look at some parts this weekend. How can I easily identify a Thing spindle? thanks |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Thu Oct 02, 2014 1:37 pm Post subject: |
Upper and lower ball joints installs from the top as Beetles has one up, one down. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Thu Oct 02, 2014 1:55 pm Post subject: |
I don't know if this will help...or not, but mine have
T6
12
cast in.
Maybe this comparison photo from the gallery will help:
Good luck, Mondshine |
Mike Sal Samba Member
Joined: May 28, 2014 Posts: 195 Location: Southern Illinois
Posted: Tue Oct 14, 2014 11:00 am Post subject: thing spindles |
Hmmm....I thought I heard that you could put thing spindles onto a bug.....is this not the case? I'm wanting some raised spindles for my '70 chassis (onto which a repro Kubelwagen is setting).
thanks,
Mike S |
Posted: Tue Oct 14, 2014 11:43 am Post subject: |
I think you will need Thing trailing arms and Thing ball joints to make it work.
I'm not sure about the torsion springs' interchangeability.
Brian Samba Moderator
Posted: Tue Oct 14, 2014 2:36 pm Post subject: |
The proper way is to use thing arms, but the other way is to flip the bottom arms from side to side. That way the bottom ball joints both point downwards. Then you use Thing lower ball joints in the flipped arms.
Also they aren't rare, but they are not common. Good luck.
Read up here: http://www.thesamba.com/vw/forum/viewtopic.php?t=606012
Here is what the other side looks like, note how much room there is for the downward facing ball joints.
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed Oct 15, 2014 4:58 am Post subject: |
Just take your bug arms and install the balljoints the correct way to fit in the Thing spindles. The only difference between bug and Thing arms is there is a slightly thicker wall on the arms on Thing. |
