Replacing Floors: Fitment Issue
ernieballbass
ernieballbass is offline
PostPosted: Sat Oct 04, 2014 2:10 pm    Post subject: Replacing Floors: Fitment Issue Reply with quote
hey guys. i could use some wisdom on how to move forward with my floor replacement Smile
so i removed the passenger side pan after taking all my measurements. i trimmed down the new floor and all the measurements are spot on! holes are 24inches from the tunnel. i started drilling holes in the floor to plug weld it to the tunnel, but i couldn't get the floor to fit snugly on the lip.
it looks like the floor ribs are keeping the floors from sitting flush Shocked Is this normal? it seems that i have two options: 1) flatten out the ribs or 2) trim down the tunnel lip...
here are the pics: 1st pic shows the problem
any guidance would be appreciated.
What I lack in brains, I make up for with good intentions.
Ron Domeck
Ron Domeck is offline
PostPosted: Sat Oct 04, 2014 4:59 pm    Post subject: Reply with quote
The right side is the one you need to move the ribs over about 1/4 in. When you get to the left side they will be Ok. Also don't rely on the indent for the bolt holes the mount to the outer body. I take the outer hole area from the opposite side, flip it over and lay it on the new pan for a pattern.
ernieballbass
PostPosted: Sat Oct 04, 2014 5:19 pm    Post subject: Reply with quote
I see. So I just need to cut out a portion of the ribs, shorten it, and patch everything together?
Ron Domeck
PostPosted: Sat Oct 04, 2014 6:42 pm    Post subject: Reply with quote
Don't need to cut, reshape the ends with a hammer and dollie.
ernieballbass
PostPosted: Sun Oct 05, 2014 2:13 pm    Post subject: Reply with quote
Sorry guys, but I got a new problem:
I drilled 1/4 inch holes around the pan and plug welded all the way around. It was all fine and dandy until I got done...and the floor popped off...welds just wouldn't hand.
My Hobart handler 140 was set at 3/30. Welds willfully in holes but won't actually weld to the lip. I'm getting a little frustrated to say the least. What on earth am I doing wrong?
ernieballbass
PostPosted: Sun Oct 05, 2014 2:37 pm    Post subject: Reply with quote
Deft to mention .030 solid wire. Argon 75/25 mix.
Ron Domeck
PostPosted: Sun Oct 05, 2014 3:32 pm    Post subject: Reply with quote
I use .025 wire. Lip on the tunnel must be shinny metal and your first pic. looks like the pan was not down and you have a space. I start in the center of the 1/4 in hole with weld and work around to the outside, not just filling the hole. I also hammer the ribs before I weld so the pan fits flush on the tunnel lip.
3Duckdaddy
3Duckdaddy is offline
PostPosted: Fri Oct 10, 2014 11:48 am    Post subject: Reply with quote
I am starting to tear down to replace pans myself. Where did you get your pans, and are you happy with the quality?
Plug or "Rosette" welding definitely has a technique. My dad does custom fab work. He had a run of fixtures that required a lot of plug welds. Start with plenty of heat in the center and work out. After you get it write down the settings so next time it will be easy work.
Thanks,
George
ernieballbass
PostPosted: Wed Dec 17, 2014 5:26 pm    Post subject: Reply with quote
Thanks,
George
oh man i'm so sorry that i didn't reply back sooner. i got the pans from a local VW shop. i managed to get em for $185 a piece. And these are the Denmark ones. they fit okay. obviously you have to trim and hammer n dolly some spots. i measured everything 500x so hopefully i won't have too many issues when i fit the body back on.
i hate to admit this, but i just couldnt get the plug welding technique down lol. youtube didn't help. the hobart manual didnt help. i just dont have enough welding experience [need a class] i ended up just doing a normal stitch weld. It's not as nice looking as the spot welds, but they hold Smile
3Duckdaddy
PostPosted: Thu Dec 18, 2014 2:56 pm    Post subject: Reply with quote
Ernieballbass,
Thanks for the reply and the pictures. I think the stitch welding looks fine. A little seam sealer and your good to go. I went ahead and got pans form cip1 and airhead parts. Getting the garage ready to start tear down soon. Keep up the progress pics.
Happy Holidays
George
mr white
mr white is offline
PostPosted: Sat Dec 20, 2014 7:10 pm    Post subject: Reply with quote
Where did these pans come from? The Thing shop ones are supposed to be ready for install with no issues. Just curious. Looking good! I ran into this issue on mine,stupid me bought another one! I bought my pans from house of ghia.
ernieballbass
PostPosted: Mon Dec 22, 2014 9:14 am    Post subject: Reply with quote
I got it from a local vw parts guy. Unless you live in orlando, you wouldn't be able to get them from him (shipping would kill you if you live in Oregon).
The thing shop has all the accessories built in and is already trimmed to fit. I didn't bother with those because:
1. I'm not putting in stock seats and I don't need the stock thing tracks
2. I don't need the seat belt hardware because mine will be mounting to roll cage.
3. I hate how the jack Receivers look (and I have never used them)
4. All the other hardware was saved from the old pans
5. I'm on a budget lol
If I were doing a full OEM restore and had some extra coin, I would buy those thing shop floors. It would save so much time!
As with everything, it really depends on what you want/need for your project and your "Intestinal fortitude" to accomplish your goals lol. It's okay to make mistakes as long as you have the drive to correct them.
mr white
mr white is offline
PostPosted: Mon Dec 22, 2014 10:44 am    Post subject: Reply with quote
What I really wanted to know was if these were the thing shop basic floors.
The halves for $250 are supposed to fit beautifully. I have not heard yay or nay on this. Hoping someone who actually bought those chimes in. Your project is coming along nicely. I just picked up a yellow 74 that will need floors as well.
citroen
citroen is offline
PostPosted: Wed Dec 31, 2014 1:49 pm    Post subject: Reply with quote
Here are a few pictures od how the Domeck Brothers ( Ron and me ) install the pans on a thing you will have to go to our website to see the rest of the story we have 70 photos on the complete installation to many to download here go to the photo gallery installing the thing pans http://kubeltreffen181.com
ernieballbass
PostPosted: Wed Dec 31, 2014 4:17 pm    Post subject: Reply with quote
Wow, I love that rotisserie! Well, maybe I'll get one next Christmas lol.
Ron Domeck
PostPosted: Wed Dec 31, 2014 4:39 pm    Post subject: Reply with quote
We made the rotisserie with 2 Harbor Freight engine stands. Some cutting, adding and making some parts. We also have heads to put the body on with a full 360 degree rotate.
