Driftin Samba Member
Joined: August 27, 2012 Posts: 141 Location: Wilsonville, Oregon
Posted: Sat Oct 04, 2014 5:37 pm Post subject: Turbo Question - Oil return line |
My oil return line (braided 10 AN with red/blue fittings)from my turbo is routed slightly up over the 2.0 Subaru motor in the picture. Do I need to pull the oil pan and install the return line downward sloping into it or will the motor work fine the way it is? I know the hot oil needs to get away from the turbo quickly. The exhaust is from Outfront Motor sports. I'm trying to get this up and running before I spend more $$ on braided lines and such.
My bumper is about 1 inch away from the exhaust but still fits this motor / turbo combo - I know the paint won't last long.
Thanks,
Ken
jsup Samba Member
Posted: Sat Oct 04, 2014 6:25 pm Post subject: |
that slight up turn in braided line shouldn't be a problem. What's that a 6AN? about 3/8 line? I wouldn't be THRILLED with it, I'd like to see it go straight down, but I can't see how it would hurt.
The most important thing you have to do is make sure the return oil goes back into the pan at the highest point in the pan. you can't have oil in the pan blocking the return. |
Posted: Sat Oct 04, 2014 7:29 pm Post subject: |
Thanks for the good news I'll keep moving ahead. The return line goes to the OEM return on the back of the head. This is a factory JDM turbo motor. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sun Oct 05, 2014 4:59 am Post subject: |
Since this is a work in process I would find a point on the engine for the drain that doesn't have the rise in it. If the oil doesn't drain away fast enough it will cause oil to leak into the turbo. Do it right the first time. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
jsup Samba Member
Posted: Sun Oct 05, 2014 5:49 am Post subject: |
lostinbaja wrote: |
Since this is a work in process I would find a point on the engine for the drain that doesn't have the rise in it. If the oil doesn't drain away fast enough it will cause oil to leak into the turbo. Do it right the first time. |
Yes. I was just going to say, going to the valve cover seems wrong. To to the oil pan. put a 45 6-an Connection, 90 if you have to, and run it to the oil pan. If there is no provision on the pan, make one.
It has to be AT THE TOP of the pan. |
Posted: Sun Oct 05, 2014 7:14 am Post subject: |
Good points, looks like putting a return into the oil pan would keep the turbo from potentially leaking oil. I can't route the line any other way to remove the rise in it. I'll add it to the list of things to do. It's a 10 AN line.
Thanks,
Ken
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Oct 05, 2014 8:05 am Post subject: |
Every Subaru turbo I have and have seen has a 5/8ths or -10 return line.
Anything smaller could cause problems.
If I were you I would route that return as straight down as possible. Going up hill is just asking for trouble.
I use push-loc hose and fittings for my oil filter and turbo return. It's not as pretty but is less than half the cost of the fancy stuff.
Mine is a VW engine but I am using the Subaru RHB5 turbo and have never had a problem with oil draining with the routing I use to the 3/4 valve cover.
As you can see in the pic it is almost a straight shot down and is 5/8ths hose off the stock drain slip fitting.
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Tue Dec 16, 2014 7:58 pm Post subject: |
I just put on my new Outfront Motor Sports oil pan and plumbed in the turbo return line. Thanks for the heads up that I needed to change my line.
