Jsg Samba Member
Posted: Wed Oct 08, 2014 6:02 pm Post subject: Hobart 140 Handler |
Ok all you Hobart 140 welders, wondering what settings you find best for your sheet metal work. Slowly but surely patching away on a '74 vert.... Just curious! |
quintenebersole Samba Member
Joined: October 08, 2012 Posts: 51 Location: Michigan
Posted: Wed Oct 08, 2014 6:24 pm Post subject: |
on my 74 baja bug i usually use about 2 on the v and about 35 to 40 on the wfs. just make sure you have a really good ground. make sure to let it cool after welding for so long. _________________ Go BIG or Go HOME |
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 348 Location: Noblesville, IN
Posted: Wed Oct 08, 2014 7:10 pm Post subject: |
I use 2 and ~40 for 20 gauge. I use 1 and ~30 for anything lighter. _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
Jsg Samba Member
Posted: Thu Oct 09, 2014 5:38 am Post subject: |
That's actually just about where I live also..... Good to know! |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Thu Oct 09, 2014 12:27 pm Post subject: |
Are you using 0.024 gauge wire or the larger 0.030? I usually am good with 1/30 with the .024 on sheet metal (I have a slightly lower power Hobart Handler 135) Hobart has that handy chart inside the door of the welder - i think it is dead on:
_________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Posted: Thu Oct 09, 2014 1:40 pm Post subject: |
I use .024 with 75/25 mix on anything lighter than 16 gauge. _________________ Kafer_Mike
Jsg Samba Member
Posted: Thu Oct 09, 2014 3:37 pm Post subject: |
Ditto |
Chad M Samba Member
Posted: Fri Oct 10, 2014 5:43 pm Post subject: |
marklaken wrote: |
I use the 135 as well but I find that my wire speed always ends up about 20% slower than indicated on the chart. I use the .023, w/ C25 mix primarily on sheet metal. |
Jsg Samba Member
Posted: Sat Oct 11, 2014 5:04 am Post subject: |
Next question, where does everybody get there sheet metal? I live in the Atlanta area and was lucky enough to find a sheet metal facility that sells their leftovers, scraps way cheap. You just have to go through the bins and hope they have the gauge you need. Usually don't have a problem as when I find some 20 I buy a bunch. Try to fab my own when I can to save $ but sometimes I have to order replacement pieces depending on how complicated the piece is. Learning as I go! |
Chad M Samba Member
Posted: Sat Oct 11, 2014 10:15 am Post subject: |
I often use old VW metal...doors, hoods, roof etc. It's the right gauge and easy to source. The other upside is that sometimes you get lucky and there is a compound curve built into your scrap that you may be able to use. I've heard some other folks using old appliance sides, but again gauge is the issue. |
