TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Wed Dec 28, 2016 12:40 am Post subject: Re: What to 3d print? |
Goodonya Heath! _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Sun Jan 15, 2017 2:16 pm Post subject: Re: What to 3d print? |
Not a bus part, but enough of us have Vanagon seats that I figured I'd post it here. I've been prototyping a 3D printed arm rest bolt cover, a part that seems to go missing a lot on these seats.
_________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
panic_fan Samba Member
Joined: April 21, 2008 Posts: 711 Location: Mcdonough GA
DougB Samba Member
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Fri Feb 24, 2017 7:52 am Post subject: Re: What to 3d print? |
Ooh, that would be pretty easy as it's flat...but getting the leatherette texture might be challenging as it would have to be part of the model. _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife |
Posted: Mon Mar 13, 2017 6:12 am Post subject: Re: What to 3d print? |
DougB wrote: |
Ooh, that would be pretty easy as it's flat...but getting the leatherette texture might be challenging as it would have to be part of the model. |
The texture wouldnt be a huge deal for me. Just an idea, as they are pretty slim pickings and $$$. _________________ Rich
Brilliant Blue/Cloud White
1970 Baywindow Bus
http://www.thesamba.com/vw/forum/viewtopic.php?t=291988&highlight=
"Still learnin the way around my VW bay"
DougB Samba Member
Posted: Mon Mar 13, 2017 6:38 am Post subject: Re: What to 3d print? |
OK, cool...and aside from the plate itself, is there anything else to it? Tabs on the back? Anyone have any dimensions?
On a side note, I printed the 17-tooth KPH speedo gear last week with satisfactory results, and am awaiting feedback from some folks to whom I sent samples. The difficult thing here is that because the teeth are smaller the resolution of the printer is more of a factor.
- Doug _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
DougB Samba Member
Posted: Mon Mar 13, 2017 7:30 am Post subject: Re: What to 3d print? |
Probably, if I had the pieces to create the model from...would need to know the strength and flexibility requirements, too, if any. But the bigger question is how you'd get the new piece in there...is it riveted together? _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
Posted: Mon Mar 13, 2017 8:18 am Post subject: Re: What to 3d print? |
I have not taken one apart and don't one at this time,I have seen where others have removed this part and glued it together,the switch is very hard to find and it seems that this plastic piece is the main cause of it failing. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
DougB Samba Member
Posted: Mon Mar 13, 2017 8:32 am Post subject: Re: What to 3d print? |
Well, if someone can send me the pieces I can model it and try to print replacements. Sounds like others have had a similar issue with it? _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5778 Location: Los Alamos, New Mexico
Posted: Mon Mar 13, 2017 11:43 am Post subject: Re: What to 3d print? |
DougB wrote: |
<snip>
- Doug |
Hey, Doug -
On the radio blank, yes, there is a metal spring tab that latches into the back.
I have one of these plates if you would like an original to work with. What the texture needs would be a laser scanner! _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
DougB Samba Member
Posted: Mon Mar 13, 2017 1:02 pm Post subject: Re: What to 3d print? |
An original would be awesome. Either way, though, the piece might need some painting afterward to fill in tiny spaces and make it have more of a consistent surface. I've done this in the past with a thicker clear coat (for crafts) and then a real paint over top.
I'm willing to give it a try...PM me if you don't mind sending it my way and I'll give you my address. Same with that other broken part that Lil-Jinx mentioned.
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
RocketSurgeon Samba Member
Joined: May 26, 2005 Posts: 442 Location: Roseville, CA
Posted: Wed Mar 15, 2017 9:38 pm Post subject: Re: What to 3d print? |
Been modeling a bunch of projects lately. Some VW some Subaru.
Here is a radio blank, let me know if it fits. Just a bit too big for me to print on my machine.
http://www.thingiverse.com/thing:2180518/#files
Check out the rest on my "things". Got a few good things on there. _________________ 69 Westy |
Hoody Samba Member
Posted: Wed Mar 15, 2017 10:35 pm Post subject: Re: What to 3d print? |
The center piece for Bay Sunroofs were reproduced on a very limited basis. Probably a small market but those who need them NEED them. |
Hoody Samba Member
Posted: Wed Mar 15, 2017 10:54 pm Post subject: Re: What to 3d print? |
As far as the sliding door handles that are affixed to the rear of Late Westy's there isn't much to it. I have several....it's only a matter of a 1/2 inch by 1-2 inch plate afixed to the inside of the handle with 2 screws. That's it. I would be more than happy to show how to take a handle and make it work perfectly for this application. A 10 year old could do it in metal shop. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5680 Location: Manhattan, Kansas, USA
Posted: Thu Mar 16, 2017 9:33 pm Post subject: Re: What to 3d print? |
DougB wrote: |
Well, if someone can send me the pieces I can model it and try to print replacements. Sounds like others have had a similar issue with it? |
They are the parts that hold the turn signal lever in place, and facilitate cancelling on the 73ish turn signal. (Mine is a '73, has these parts broken, and is very difficult to find.)
I might have the pieces, I'll try to see as soon as I can. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Heathintexas Samba Member
Joined: September 24, 2011 Posts: 135 Location: Berlin Germany
kenfolk Samba Member
Joined: August 16, 2011 Posts: 34 Location: Arden, NC
Posted: Sun Nov 05, 2017 12:48 pm Post subject: Re: What to 3d print? |
Some random projects I used 3D printing to complete.
Parcel tray mount.
Some LED clips and mounts
Knobs for the LED dimmer.
And a table mount for a fold out table I made.
And some other doodads
Coasters, spare knobs and misprints
_________________ 78 Westy |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Sun Nov 05, 2017 5:37 pm Post subject: Re: What to 3d print? |
you could prob never find one for reference, but the male end for the diagnostic plug. You would have to use the female to get a usable mold (on a side note, I am calling the part with the pins and spades sticking out as the male end, even tho the plug in the bus does the sliding in action)I have read some interest in folks using the plug as an elect start, trailer light access point, and some other apps. |
