Mayor Marion Berry Samba Member
Joined: August 30, 2014 Posts: 119 Location: Fredericksbug VA
Posted: Fri Oct 10, 2014 12:36 pm Post subject: My 59 mini project, let me show you it |
Drove it around the block so it's finally and technically road worthy!!!
Heres a small imgur album, for some reason I could only upload 7 photos.
Previous car was a 94 miata R package, however this lady decided she wanted to be in my lane more than I did so her insurance company bought me this jade green (I think) 59 bug with a brand new chassis.
Ever since watching the love bug as a kid, I've always wanted an old bug. Now I finally have one!!
I picked it up from NC and trailered it back to its apparent home of VA due to the old AAA sticker on the rear bumper. Before driving down to purchase, I purposefully didn't show the GF andy pics of the interior including the dangling headliner since I knew she wouldnt approve. Didnt matter anyway because she noticed the birds nest in the glovebox before I got a chance to get rid of it once I got it home. That was a tough one to explain away.
As it was it needed to be "finished up". It can drive, kind of turn and sort of stop and thats about it.
The engine is a 1300 from either a 66 or 67. It's hard to read out the engine number. Either starts with a E or an F. Not at all 100% certain. J pipes, some kind of muffler and its LOUD. OMG is it loud. I was told it was a 6 volt system, but after poking around it's a 12 volt I dont know for sure.
Suspension consists of a 6 inch narrowed beam, drop spindles of some kind. 145/65 tires up front and 175/55 in the back.
I've started the process of changing out all the window and body seals. So far the rear quarter window is a huge pain in the ass and Im thinking of paying someone else to do the rear window and front windshield once I finish. I've been trying off and on for a bout a month now
I still have to wire up the speedo, fix the scary loose steering, get all the lights working and figure out why and fix the stiff front passenger side wheel. Oh and that whole "is it a 6 or 12 volt system??".
My goals are to leave it as stock as I can and it will be my daily driver. I am in love!
Last edited by Mayor Marion Berry on Tue Oct 28, 2014 1:37 pm; edited 1 time in total |
grandpa pete Samba Member
Kierdan Samba Member
Posted: Sun Oct 12, 2014 4:56 am Post subject: |
Good luck with your project. I am pretty sure the engine came from a 66. Someone else on here will know better but almost 100% sure U.S.67's all came with a 1500. European 67 bugs came in both 1300 and 1500. And I think your engine code is an F. I had a 67 like 20 years ago and I think mine was an H.
Danny |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sun Oct 12, 2014 6:43 am Post subject: |
The engine number starts with an F, that line that makes it look like an E is just a casting flaw or a deep scratch.
It may have started life as a 1300, but the intake manifold and carb are from a later model like '69 or '70.
Although they do make a big 6V Generator, yours is likely 12v given that it has that transistorized Voltage Regulator stuck on the fan housing. The GEN or VR should both be stamped somewhere with their ratings, have a close look. One thing is for sure, those wires to the VR are way too small, the B+ should be at least 12 gauge for 12V, or 10 gauge if it's still 6V.
Also, many things wrong with the cooling system, number one being the missing heater hoses, followed closely by missing plugs in the Fan Housing, poor fitting tin etc. These are some of the very first things to address before driving too much at all.
That, and get ready for the forum to shout "Get that fuel filter out of the engine compartment ASAP!"
That AAA sticker appears to be stuck to a late '67 rear bumper. Those over riders are worth more to a '67 owner who needs them, so consider looking for some early ones to swap with and sell those.
Funny thing is, sure looks low in the back for not having any negative camber, maybe the small tires are contributing to the drop?
Brand new chassis, or brand new floor pans? With a "new" chassis, you shouldn't have any scary loose steering, or dragging front wheel
These sorts of mechanical defects simply require getting in there and checking things one by one.
Finally, the rear quarter glass is one of the easiest to install, so if you're having trouble with them, check to make sure you have the correct seals, and that they are of the highest quality you can afford _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Fri Oct 24, 2014 11:02 am Post subject: |
Thank you all!!! Don't know why I didn't check this thread sooner.
I'll get right on top of dealing with the engine compartment for wiring, relocating the fuel filter etc etc. It's not going anywhere anyways, since it's on jacks. I started the process of thinking about how to go about starting the front brake work. Right front wheel is beyond tight and I can't adjust one of the star spindles to adjust the brakes, seems to be stuck. Finally was able to hit the local pawn shop for essential tools so I can get started! Woot!!!
I didn't realize my bumper was from a later model, Think I will sell it for a stock one so goodbye mr cool AAA sticker!!! |
jack1448 Samba Member
Joined: October 27, 2012 Posts: 272 Location: Northern NJ
Posted: Fri Oct 24, 2014 1:28 pm Post subject: |
Looks like original L243 diamond grey paint, at least most of it. Very cool. You don't see that around very often anymore! Good luck with the build. |
61SNRF Samba Member
Posted: Fri Oct 24, 2014 6:46 pm Post subject: |
Mayor Marion Berry wrote: |
Right front wheel is beyond tight and I can't adjust one of the star spindles to adjust the brakes, seems to be stuck. Finally was able to hit the local pawn shop for essential tools so I can get started! Woot!!! |
1-Spray the adjuster threads once a day for a week or so through the adjustment hole with a good rust penatrent aerosol with an extension tip. WD40 if thats all you've got, but there are much better alternatives. Google it. Ultimately this is probably going to saturate and thus ruin the brake shoes so plan on replacing those during repairs.
2-If after soaking the adjusters still won't turn with a brake adjuster/ large flat tip screw driver, line up the adjuster hole in the drum just right to insert a ~3/16" punch so it's tip is on an adjuster notch, then hammer on the punch to force the adjuster wheel in a loosening direction. Threads on them are all standard/right hand, so orient yourself whether upside/downside and go righty tighty, lefty loosey. Once you get it to move or turn, start spraying it down again. repeat until the shoes don't drag, then remove the drum for full inspection. _________________ -Bruce
Rathguten Samba Member
Posted: Sat Oct 25, 2014 8:10 am Post subject: |
Welcome to the '59 club! Your car look great. Make sure to browse through the 58-59 sticky as there is plenty of great information there. 58-59 are my favorite years. Here is my latest '59 build. |
stale air Samba Member
Joined: August 23, 2007 Posts: 5152 Location: Senoia Ga, formally NorCal
Posted: Sat Oct 25, 2014 9:56 pm Post subject: |
Rathguten, good looking 59, nice Honda 70! _________________ WANTED: Henry Veale Santa Rosa plate frames
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
Posted: Sun Oct 26, 2014 8:50 am Post subject: |
Rathguten wrote: |
Is this your car in a garage tico ?? no way !!!!!!!!!!!!!!!!! sweeeeeeet _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
Posted: Mon Oct 27, 2014 1:11 pm Post subject: |
Thanks all! I went ahead and took apart the brakes to investigate. I wanted to push out the pistons in the wheel cylinder just a little bit and see if they retracted like I thought they should (again, first car I've ever really worked on so I'm going by stupidity and brawn) and I thiiiiink I may have pumped a little TOOOO much.
http://i.imgur.com/2DCEWdB.jpg?1 KABLOOEY!!!!
http://i.imgur.com/dkfF4VB.jpg?1
http://i.imgur.com/Jh12JHT.jpg?1
I went ahead and took it all apart, washed everything in DOT3 brake fluid and put it all back together again. Other than the pistons being very tight against the cylinder wall, I don't think I have any issues since there are no gouges in the wheel cylinder and the rubber pieces and spring seem very fresh still. If it doesn't leak will I be ok in terms of the wheel cylinder?
This is what my drum look like. It has a very noticeable rough patch. Is is ok or should I replace?
http://i.imgur.com/ke9fqDY.jpg?1
http://i.imgur.com/V8NR1xM.jpg?1
http://i.imgur.com/MDGqgRu.jpg?1
....aaaaaand as for the steering, my steering box seems bone dry. Do I fill it with 90 weight gear oil or should I just add so much. Where I have it circled in the next photo is where all the freeplay in my steering seems to be. All nuts are tighter than my wallet.
http://i.imgur.com/gWSw1NG.jpg?1
http://i.imgur.com/nwMb77d.jpg
I feel like the annoying kid in class right now, asking too many questions and having zero clue |
ThorpS18 Samba Member
Joined: November 19, 2009 Posts: 160 Location: So. California
Posted: Mon Oct 27, 2014 9:30 pm Post subject: |
I would have both of the front brake drums turned. I just had the drums on my 66 done for $10 each.
You said you washed everything with DOT3 brake fluid. Did you use brake fluid to clean the shoes? If you are going to try to use those brake shoes they need to be cleaned thoroughly with brake cleaner. Personally, I would replace the shoes since they have been saturated with brake fluid and it might not be possible to get all the fluid out of the linings.
Nice car. Keep up the good work. |
61SNRF Samba Member
Posted: Tue Oct 28, 2014 5:04 am Post subject: |
Brake Drums, like shoes, are considered expendable and have a wear limit. You can expect to get about 3 brake jobs or between 50-100,000 miles out of them.
When they rust like your photo shows, the metallurgy changes and that area is now harder with a difference in friction potential.
This can result in a vibration or pulsation in the brakes.
When turned or machined, the tool will often just skip over that area, leaving a lump or hard spot.
And, drums can only be turned so much, once their wear limit is reached, it's time to trash or recycle them.
I'd want new drums and shoes on there if it were me. _________________ -Bruce
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
Posted: Tue Oct 28, 2014 5:49 am Post subject: |
That steering coupler is shot. I wouldn't go anywhere on that, not if my life depended on it. A quality one is 20 bucks, a cheap one is 10. _________________ Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807 |
Posted: Tue Oct 28, 2014 6:14 am Post subject: |
Thanks again!!!! A pair of new shoes and drums and a new coupler it is then. I was thinking about swapping the steering column for a 67 for a smidgen of safety anywhoo
*edit*
are Italian brake drums close to being as "good" as German? There seems to be QUITE a price jump between the two. German being $105 each, italian being $65 each.
*double edit*
screw it, bought 2 new italian rotors and shoes to go with them. |
Posted: Sun Sep 17, 2017 2:54 pm Post subject: Re: My 59 mini project, let me show you it |
After 3 years and many headaches, Its road worthy!!! Successfully made it to the gas station , grocery store and even a local show. Yay!!!!
Heres whats been done so far...
-"cleaned up the engine", since I have j pipes I replaced the fanshroud for one without those heat outlets and moved the fuel filter to the front of the car.
-upgraded brake master cyl to a dual, fixed brake fluid leaks and lines
-fixed the transaxle fluid leak, while in the process pulled out an axle (oops) and learned how to drop the engine and tranny. Took the tranny to someone that knew how to fix my f-up.
-fixed the oil leak aka exxon-valdez and got oil everywhere in the process
-4 new smart car tires and 15x5.5 mangels in the back
-I think I fixed the steering
-new horn button that doesnt work yet*
-seatbelts for an illusion of safety
-speedo now works
-"porsche" style headlights that dont work yet*
-pop outs
-bought all kinds of parts that I thought I needed, but didn't
still to do
-no lights work*
-weird whirring noise coming from the back
-the wife still wont ride in it.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Sep 17, 2017 4:17 pm Post subject: Re: My 59 mini project, let me show you it |
Great to see it out on the road!! _________________ In Stereo, Where Available! |
