gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Fri Oct 10, 2014 6:57 pm Post subject: Low friction generator? |
I was reading how someone gained 3HP at 4000 RPM by replacing a 28 blade fan with an early 16 blade model. I suspect our generators also eat up a lot of precious horsepower. Has anyone tried installing ceramic bearings in their generator? If so, did it make a difference?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1275 Location: australia
Posted: Fri Oct 10, 2014 9:07 pm Post subject: |
I haven't tried it but I like the way you think.
reducing the contact surface area of the brushes should be good for 0.0002mph on the salt.
treuhaft did a aluminium fan in the 80's, I think it was a 28 blade though.
fan design seems to me to be an area with good potential for bolt on hp savings on all t1 motors, I wish I had the engineering knowledge and funds to design one that worked and get it on the market. |
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Fri Oct 10, 2014 9:29 pm Post subject: Re: Low friction generator? |
gimmesomeshelter wrote: |
Cheers,
Paul |
8 blades--Porsche did this.
I think disabling the charging system by disconnecting the field (DF) wire would help more than slippery generator bearings. |
grueni Samba Member
Joined: November 03, 2008 Posts: 582 Location: Germany
Posted: Sat Oct 11, 2014 4:41 am Post subject: |
the 16 blade has also better cooling.
i did once 3 bearings in the generator instead of 2 and it sucked energy.
but i would not go with other bearings. _________________ 1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile ) |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Sat Oct 11, 2014 11:07 am Post subject: |
wouldn't you get the same effects with a smaller bottom pulley? _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
