jorem50 Samba Member
Joined: October 12, 2014 Posts: 2 Location: Lakeland Florida
Posted: Sun Oct 12, 2014 11:00 am Post subject: Going to look at this today! Any suggestions for a novice! |
Wanting to dune a dune buggy project. Going to look at this today as maybe a starting point. Any suggestions as to what to look for? I am new to dune buggies and VW's so I am starting at ground zero.
Thanks for the advice.
The pic is in my gallery. Don't know if there is a way to add it to the post or not.[/img] |
WD-40 Samba Member
Posted: Sun Oct 12, 2014 11:37 am Post subject: |
Welcome to TheSamba!
There's a section at the top right, when you're viewing the image in the gallery, called "Forum code:". Just copy/paste that into your post, and you're good to go. _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Sun Oct 12, 2014 6:39 pm Post subject: |
Check for:
*Rust
*Try to see if the frame is straight or has a twist. Take a measuring tape and a level
*Wiring. This speaks VOLUMES about the overall build quality
*Suspension condition.
*Motor & trans.
Even if ALL that is bad there's still some value to the buggy. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Posted: Sun Oct 12, 2014 6:59 pm Post subject: |
Thanks! I passed on that one! I think I'm leaning towards buying a chassis from acme car company and build it off of that!
Going that route do you think it's still worth buying a donor car! Haven't found any bugs with a title that are cheap enough but I have found a couple without title. If I'm not using the chassis is the title important?
I do want to do 4 wheel disc brakes so besides engine and transaxle how much of a donor car would I use?
Sorry for so many questions just like to have a solid plan before I get started. |
Posted: Sun Oct 12, 2014 7:12 pm Post subject: |
It's always cheaper to fix up a buggy that's already been built. If you buy from Acme, do your research on titling in Florida first. It can be a pain here sometimes. A buggy that's already titled in FL saves you a LOT of worry & grief. _________________ www.LoCashRacing.org
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Mon Oct 13, 2014 6:48 am Post subject: |
Buy a used one that need attention. Far easier to fix a lot of small things and possibly still enjoy driving it. Buy a kit and it will sit there for years (voice of experience) - and possibly your kids will have to finish it. Disc brake all around on a dune buggy probably aren't needed. Disc in front are cheap but ones with an emergency brake for year are much more costly. Both are easy up grades down the road. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
truckdude Samba Member
Joined: May 01, 2014 Posts: 148 Location: Beverly Hills baybee
Posted: Mon Oct 13, 2014 9:18 pm Post subject: |
I think I have the same front wheels as that buggy and I scored four of those hubcaps in almost mint condition for $15 this weekend. They won't clear the front hubs by about 1/2" on my '63 rear end. Any secret on getting these to fit? Wheel spacers and longer lugs? |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Oct 14, 2014 1:47 pm Post subject: |
truckdude wrote: |
Front hubs on a 63 rear end.. may be the whole problem..
Go slow test fitting each time..
Couple of things to do to make hub caps clear either the dust cap or axle.
Make sure the dust caps are fully seated.. grind a little off the top of the dust cap or rear axle snout..
Also use a rubber mallet and a sand bag to gently pound the center of the caps out evenly. .. ... just need enough to clear and snap on.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Tue Oct 14, 2014 3:01 pm Post subject: |
haha, front hubs on a 63 pan is what I meant to say. Caps don't clear the dust covers. Driver's side has the speedometer cable sticking out. I still need to get the clips added.
Edit - I'm an idiot, dust caps are sticking out about 1/2", I have not tapped them into place yet after rebuilding the front end. |
