Jared2880 Samba Member
Joined: January 08, 2014 Posts: 4 Location: Grand Rapids Michigan
Posted: Mon Oct 13, 2014 5:46 am Post subject: 80' Diesel Pickup Fuel Pump? |
Does a 1980 Rabbit Diesel Pickup have a fuel pump in the tank? I am thinking no. My belief is that the fuel is brought into the engine by the injection pump?
Thanks for responses, |
Posted: Mon Oct 13, 2014 7:17 am Post subject: |
Also, starts up really hard and there is a tone of white smoke. Only way to keep it running is to keep foot on the gas. It will not idle. I hooked up the fuel system to a similar diesel truck and it ran fine. I ran it through my fuel filter. My though is that if there is no fuel pump that there is an air leak in the fuel line or algae build up in the tank? |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Mon Oct 13, 2014 7:23 am Post subject: |
No fuel pump in the tank . The injection pump alone draws the fuel from the tank .
I know black smoke is running rich so (maybe) white is lean ?
If running lean try looking for suction leaks in fuel supply lines . Cracks . loose fittings etc. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
stewardc Samba Member
Posted: Thu Oct 16, 2014 5:47 am Post subject: |
Will it run OK after it warms up a little?
If so, it's glow plugs. Even one bad makes for a hard start and LOTS of white smoke. |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Wed Nov 05, 2014 9:54 pm Post subject: |
Check your timing, white smoke in diesels is usually unburnt fuel from too advanced timing _________________ foam cowboy hats aren't good helmets. |
air-h2o-air Samba Member
Posted: Thu Feb 12, 2015 11:28 pm Post subject: |
Jared not 100% positive on a filter/screen in fuel pickup in the fuel tank but I'm betting there is...VW used it in Rabbits...Id assume PUs too |
weisswurst Samba Member
Joined: May 07, 2013 Posts: 233 Location: south florida
Posted: Fri Feb 13, 2015 5:08 am Post subject: |
tripicana wrote: |
Check your timing, white smoke in diesels is usually unburnt fuel from too advanced timing |
100% correct! I just re-timed my 82 1.6na pump in my singlecab vanagon (identical to the rabbit setup) and it stopped running rough at first and stopped
all that scary white smoke I had at startup too. First time I used my new timing indicator tool and it made a big difference in power too.
I can now break 46 mph!
turns out it was waaaay off from the PO.
jeff |
