Window felt
reluctantartist
reluctantartist is offline
PostPosted: Tue Oct 14, 2014 6:27 am    Post subject: Window felt Reply with quote
Will the beetle window felt channels work in the 412 estate. I noticed there are one window channels which might be lone enough.
1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them.
raygreenwood
raygreenwood is offline
PostPosted: Tue Oct 14, 2014 6:36 am    Post subject: Reply with quote
Oddly enough......I dont know. I have never gotten to the point of replacing mine.
I have had the felt inserts out....the metal rim with the felt in it......for painting before. Its kind of tricky getting it out. Just be patient.
From what I remember it should not be too hard to put new felt in the original trim ring.
Let us know what you discover.
Ray
bb412
bb412 is offline
PostPosted: Tue Oct 14, 2014 1:40 pm    Post subject: window felt Reply with quote
i have change the old felt with the felt for home sliding window felt,with an super glue,, on the metal,, that work fine,,,
reluctantartist
PostPosted: Thu Oct 16, 2014 5:52 pm    Post subject: Reply with quote
I am planning to do that for the scrapers but i am getting the beetle felt channel to see if it will work as my felt channels are worn and not sealing well.
bb412
bb412 is offline
PostPosted: Fri Oct 17, 2014 3:13 am    Post subject: window felt Reply with quote
hi,, you can do an oder thing,, change the right side inner felt for outside driver felt,,if it is betther,,they are the same,,
reluctantartist
PostPosted: Mon Nov 03, 2014 7:42 am    Post subject: Reply with quote
Well the beetle channels will not work. I should have taken a closer look at the 412 channels. They are unique. They do not have a felt insert like most channels. I saw on a hotrod forum that people use velcro loop for this. So that will be my next thing to investigate.
raygreenwood
PostPosted: Mon Nov 03, 2014 7:15 pm    Post subject: Reply with quote
Take a look at the Auveco website first and see if they have anything useful.
your coil and bushing should be in any day. Ray
