nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
vwpackrat Samba Member
Posted: Wed Oct 15, 2014 11:46 am Post subject: |
ive had a copper fuel line on my vert for 15 yrs..........previous owner ran it thru the convertible support rails _________________ 62 Convertible Bug
67 Westfalia |
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1083 Location: Dover, DE
Posted: Wed Oct 15, 2014 11:51 am Post subject: |
I would think the only problem would be that its a soft metal that would cut or crack easily causing undesirable results _________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
Posted: Wed Oct 15, 2014 12:10 pm Post subject: |
on mine it does not run into engine compartment etc......they basically ran it thru the support rail then has rubber lines from each end there to tank and engine compartment. But yes copper is a lot softer metal than ur other fuel line types. _________________ 62 Convertible Bug
67 Westfalia |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Wed Oct 15, 2014 12:20 pm Post subject: |
Hell.. if you really wanted to.. you could use rubber fuel line front to back..
IMO.. copper fuel line. is not the best choice.....
Will it work.. sure..
but.... why use it ...when you can use stainless or aluminized brake tubing just the same...
A 25 foot roll of 1/4 brake tubing cost about 20 bucks at Napa or the "Flaps" stores with no shipping. ...Plus then you haven plenty for the hard line at the engine.. .. (and dont have to use the crappy "German" fire hose)
.. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Wed Oct 15, 2014 12:48 pm Post subject: |
Maybe its just an old wive's tale, but I was under the impression it was illegal to use copper tubing for fuel line in a motor vehicle. It's soft, so it will easily chaffe, and it work hardens and cracks, or so the "story" goes. _________________ 1958 Karmann Ghia owner |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Wed Oct 15, 2014 1:08 pm Post subject: |
They have been using copper fuel lines in commercial equipment for years. The issue I see is the rubbing & chaffing from it not being secured properly. That holds true for any kind of line. _________________ I think he meant "rare", as in "not well-done" |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Oct 15, 2014 3:05 pm Post subject: |
Better to use it as a fuel line then as a brake line.
Many years ago I had a guy in the neighborhood bring me his beetle. He had replaced the main brake line to the rear and couldn't get a good pedal. They would bleed it, get a good pedal and then it would go away very quickly. After several hours of messing with it, he brought the car to me.
I looked under the floor mat and discovered the copper line he had installed was about as big around as your finger! I think it was probably about 2 pedal pumps away from exploding. _________________ Mother Nature is a Mean Evil Bitch! |
Mike Sal Samba Member
Joined: May 28, 2014 Posts: 195 Location: Southern Illinois
Posted: Wed Oct 15, 2014 4:06 pm Post subject: Copper fuel line |
As a blacksmith who has forged a lot of copper over the years, I can tell you that tubing starts off soft & will stay soft until stressed. If not secured from movement of vibration, it will work harden. That's when it can crack if it continues to experience movement.
When forging, you have to stop & anneal copper after just a few minutes of working it.
I personally will not use copper line in a vehicle although a lot of people have gotten away with it.
Mike Sal |
ThorpS18 Samba Member
Joined: November 19, 2009 Posts: 160 Location: So. California
Posted: Wed Oct 15, 2014 5:20 pm Post subject: Re: Copper fuel line. Bad idea? |
I purchased and am using that fuel line in my 66 beetle with a 1600. It has good bends and therefore fits well. Per my engine rebuilder's suggestion, I slid rubber fuel line on the outside pretty much the full length, except where it goes through the grommet in the front tin. I also used an adel clamp http://www.aircraftspruce.com/catalog/appages/0400920.php at the side of the fan shroud to secure it.
It's working well until I can find an original one in the classifieds. |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Wed Oct 15, 2014 6:33 pm Post subject: Copper fuel line. Bad idea? |
Were copper lines ever a VW factory installation? I thought not. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76903 Location: Sneaking up behind you
Posted: Wed Oct 15, 2014 6:37 pm Post subject: |
Any copper fuel line you see in a VW is copper coated steel and not solid copper. _________________ Glenn
Member #1009
#BlueSquare |
bluebus86 Banned
Posted: Thu Oct 16, 2014 8:53 am Post subject: |
copper is fine, BUT it must be secured from rubbing, and vibration. it will tend to work harden if vibrated and bent, securing it solves this issue. rubbing will wear thru soft copper faster than steel, again securing it will prevent this. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Oct 16, 2014 8:58 am Post subject: |
^ Ha.. all that... so why why not just use coated steel..
Jus sayin'
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Thu Oct 16, 2014 9:03 am Post subject: |
Years ago a friend came over with a copper fuel line in her bus. The line was laying on the heat riser tube, so tried to bend it slightly to get it off the pipe and the copper line snapped. Pouring fuel all over the place.....
Got her a steel VW fuel line and never had a problem after that. _________________ In Stereo, Where Available! |
wardvwracer Samba Member
Joined: July 19, 2002 Posts: 489 Location: De Pere, WI
Posted: Thu Oct 16, 2014 2:53 pm Post subject: |
When I tore apart my '62 for the body removal I found that a prior owner had run a copper line past the pedal assembly and along the tunnel inside the interior to the rear of the car. I was a bit surprised by this.
Said copper line has been removed and is rolled up into a nice coil. Not sure what I'm going to do with it, but its not going back on the car in the new build. _________________ David Ward
ACME Berrien Buggy Street/Strip racer build
1963 Single Cab
1969 Beetle Convertible
63 11-Window Kombi Bus
Cornpanzers |
Glenn Mr. 010
Posted: Thu Oct 16, 2014 2:59 pm Post subject: |
PO's... gotta love them, because killing them is against the law. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Oct 16, 2014 3:12 pm Post subject: |
Glenn wrote: |
PO's... gotta love them, because killing them is against the law. |
True! Check out the hole punched in the tunnel in my tread on my 62...
http://www.thesamba.com/vw/forum/viewtopic.php?t=608337 _________________ David Ward
1963 Single Cab
Cornpanzers |
briansandiego Samba Member
Posted: Thu Oct 16, 2014 4:11 pm Post subject: Re: Copper fuel line |
Mike Sal wrote: |
Mike Sal |
This ^^^
If I'm going to take advice from anyone regarding metal its going to be from a blacksmith! _________________ Stock'ish 1968 Beetle |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
