mbjeeper Samba Member
Posted: Wed Oct 15, 2014 2:14 pm Post subject: 1967 doors different? |
I need a pair of doors for my '67 Squareback.
The doors I have found are several hours away and I'm going by pics only. They are in good shape, but I have heard that '67 doors are different in some way. I know that they radically changed in '68, and these are definitely early doors, with old style door handles, but what are the differences, if any between , say, a '66 and '67 door?
I can see that the lock button at the top rear is not there on the replacement doors, but I can add that if everything else will work.
I have been told that the hinge is different. Is this the case? If so, what is different? Can I knock out the hinge pin and use my door pillar side hinges? Or is the hinge that is welded on the door itself different as well?
I am not too up on Type IIIs, and I'd really appreciate some info so I can decide whether or not to buy these doors. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Oct 15, 2014 3:42 pm Post subject: |
Squarebacks to to mid '66 & all notchbacks had 3 bolt hinges & won't fit on a '67 square with 2 bolt hinges. The hinges are welded on and can't be easily changed, so don't buy doors with 3 bolt hinges! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Wed Oct 15, 2014 4:17 pm Post subject: |
Where are you located? _________________ Bus Motor Build
What’s That Noise?!? |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1164 Location: Las Vegas, Nevada
Posted: Wed Oct 15, 2014 11:32 pm Post subject: |
67 has a lock button at the back of the glass on 67 only doors. 68 had it but the outer door handles changed along with the door panels. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
Posted: Thu Oct 16, 2014 5:13 am Post subject: |
I'm near Wheeling WV.
If the hinge pins are knocked out of the hinges on these 65-66 doors, can I then use my 2 bolt hinge from the old (existing '67) doors on the car side of the hinge pin to bolt them to my pillar?
Or are the hinges that are welded on the door in a different location? I have nothing to compare to here.
Thanks,
Greg |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Oct 16, 2014 5:56 am Post subject: |
flyinglow94 wrote: |
67 has a lock button at the back of the glass on 67 only doors. 68 had it but the outer door handles changed along with the door panels. |
Yep-essentially a one year only door. |
Posted: Thu Oct 16, 2014 3:53 pm Post subject: |
mbjeeper wrote: |
Thanks,
Greg |
The door skin and structures are pretty much the same with the acceptions of the latch hole by the glass but i couldn't say with 100% certainty that the pins and hing would just swap out (my luck is the hinges would be bad). One other thing on the 61-66 doors is that there latches tend to go out and are expensive to get when you need them. 67 is a one year only latch but they are stronger and are the same as 67 bug. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
