rrankin Samba Member
Joined: November 10, 2004 Posts: 287 Location: Austin Texas
Posted: Wed Oct 15, 2014 3:20 pm Post subject: removing the stub axle w/o the special vw tools |
Is there a good or easy way to remove the stub axle from the trailing arm?
I have new wheel bearings and outer and inner seals, I don't have a new spacer sleeve for either side.
I don't have a press either.
What is the best method of removing these items from the trailing arm?
Should I undertake this prior to removing the arm from the car?
Thanks a million. _________________ '74 Thing [Fritz]
Austin, TX |
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Wed Oct 15, 2014 5:23 pm Post subject: |
it has been a while since i was down that road.
you can do it easily while arm is on the car. you will need
snap ring pliers. no need for a press. dig out all the grease. there should be a snap ring buried in there that keeps things from coming apart.
there is a exploded diagram out there. just cannot put hands on it at this moment |
Posted: Wed Oct 15, 2014 5:55 pm Post subject: |
63ziggy wrote: |
I have the diagram. The snap ring is on the side of the bell housing CV side, so do I just pop it with a rubber mallet? _________________ '74 Thing [Fritz]
Austin, TX |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
germanbilly Samba Member
Joined: October 18, 2013 Posts: 378 Location: Victorville
