notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Tue Oct 21, 2014 8:42 am Post subject: |
The heat exchangers on the motor are for regular daily driving, used all the time to keep you warm, window clear and what not. The Eberspacher is meant as a secondary heater to that for when its really cold or you are parked for any duration.
Dont think of the Eberspacher gas heater as your primary daily use heater. Thats what the motor heater boxes are for.
The Eberspacher was advertised as the secondary heat to warm you up while the motor was coming up to temp. Then turned off until the next day or if you park and need some heat while the motor is off.
Imagine a cold morning that Im sure you get in your neck of the woods - the Eberspacher being set to run 15 min prior to you leaving for work. You enter a warm toasty bus. That and keeping you warm while camping is primarily what its for. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Estacaco Samba Member
Joined: October 16, 2014 Posts: 105 Location: Dryden, Ontario Canada
Posted: Tue Oct 21, 2014 8:47 am Post subject: |
That's kinda what I figured. Yay more parts to source! |
Posted: Sat Oct 25, 2014 6:18 pm Post subject: |
Fighting the good fight. Lots of bondo to remove.
Also pulled the single carb intake off the engine. all the inner intake manifold studs came out with the nuts for some reason.
Also been fighting with the engine tin screws. I've soaked them in PB Blaster, hammered them with and without a screwdriver and sweared at them all to no avail. Tomorrow I will try again but with heat added to the mix. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sat Oct 25, 2014 9:51 pm Post subject: |
KanoKroil works better then pblaster. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
knightsofni Samba Member
Posted: Sun Oct 26, 2014 6:28 am Post subject: |
Just an FYI
Concept1 distributes Klassicfab metal in Canada
Congrats on those busses, you got a killer deal for Canada
Regards
Knights _________________ 1978 VW Bus Westfalia 2.0L FI
72-74 Heating and Exhaust |
Posted: Sun Oct 26, 2014 2:42 pm Post subject: |
knightsofni wrote: |
Just an FYI
Regards
Knights |
Ya I saw Concept1 sold them.
Today got the rest of the bondo off.
Also managed to pull half of my heater hoses off.
Posted: Sun Nov 09, 2014 10:41 pm Post subject: |
Toying with the idea of doing a water-cooled swap to an ABA or possibly some other donor.
Posted: Thu Dec 11, 2014 5:30 pm Post subject: |
I have found a Ghia Pancake engine in town that is practically free. Will that drop into my bus? or at least have useable engine parts? at the very least I can use the flywheel correct? |
Posted: Thu Dec 11, 2014 11:13 pm Post subject: |
A T3 Ghia pancake or a T1 Ghia motor? Neither is a good idea and no parts will work. The water pumper was a far better idea. _________________
t3kg wrote: |
1964 1500 S
Posted: Sun Apr 26, 2015 9:14 pm Post subject: |
Does that sticker mean I have a 74?
Can't seem to get these cooling tin screws out.
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
1967250s Samba Member
Posted: Mon Apr 27, 2015 11:22 pm Post subject: |
"74 sticker means the fan shroud is from a '74 engine. VIN tells you year of Manufacture. _________________ '72 Elm Green Deluxe |
Ginger Rogers Samba Member
Joined: November 03, 2014 Posts: 29 Location: Suffolk, U.K.
Posted: Thu Apr 30, 2015 2:30 pm Post subject: |
Hi. I'm enjoying your thread as I too have a '73 Westy.
What is your VIN and engine code and number? I'll look them up in the Specification Guide. _________________ 1973 Campmobile Automatic. |
Posted: Fri May 01, 2015 4:49 pm Post subject: |
Havnet pulled the M-code yet,
VIN 2332206271 brings back
Year: 1973
Make: Volkswagen
Model: Type II Kombi/Campmobile
Sub-Model:
Style: Microbus 3 Door
Engine:
Can't pull the tin to find engine code. |
Posted: Sat May 16, 2015 3:44 pm Post subject: |
Use an impact they said. It'll be easier they said.
Posted: Sun May 24, 2015 7:12 pm Post subject: |
Progress finally
What is this? Why is it plugged? How do I remove it so I can take my engien tin off?
Posted: Sun May 24, 2015 7:27 pm Post subject: |
Unscrew it out like a normal bolt. Its part of the smog pump system the later carbureted buses had o pass emmissions. I have the same on my 74 motor but I replaced them with normal bols as the hole goes into the combustion chamber.
Im still interested in all that eberspacher stuff if you want to let it go _________________
t3kg wrote: |
1964 1500 S
Posted: Sun May 24, 2015 7:36 pm Post subject: |
That's what I thought but the down side is they're just gonna snap off, gave them a bit of a twist and the shaft is twisting on itself.
I'm getting there with the heater stuff lol. |
Posted: Sun May 24, 2015 8:28 pm Post subject: |
Thanks i'll give that a try. Any other bits that need to come off besides the screws? Distributor? |
