Mr_Rednexican Samba Member
Posted: Fri Oct 17, 2014 1:10 pm Post subject: brake issues |
hey there i have a 67 baja and the guy i bought the car off of said he put a 62 trans in it. it came time for new drums cause the lug holes stripped out. but anyway i bought new drums for a 62 but when i put everything back together the axle nut didnt reach the the drum there was about 1/8 inch gap between the drum and the axle nut. so i put the old ones back on and realized they had the same problem. how do i find out what drums i need |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Fri Oct 17, 2014 1:40 pm Post subject: |
Sounds like you need 67drums, Long splines. Or have a hardened spacer made. _________________ foam cowboy hats aren't good helmets. |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2649 Location: West Coast (Michigan's)
dustymojave Samba Member
Posted: Mon Oct 20, 2014 6:58 am Post subject: |
tripicana wrote: |
Sounds like you need 67drums, Long splines. Or have a hardened spacer made. |
Correction...
67 drums are NOT long spline. The 67 uses long axles with short splines.
68s got long axles with long splines, as used on swingaxle Type 3s. IRS Bugs have the long splines just like 68 swingaxles, on their stub axles.
62 and 67 drums should be interchangeable. The only visual difference being that 62 drums have a smooth taper from the wheel mounting face to the axle nut, while 67 drums have a 5-spoke pattern cast into the face of the drum between the wheel mounting face and the axle nut.
Rednexican should NOT need anything custom machined. It's possible that a spacer is missing inside the bearing cap. There should be a thick spacer (close to 1/2" thick) just inboard of the drum, then the bearing, then a thinner (about 1/4" thick) spacer. The spacers remained the same from 1961 through 68 swingaxle. There was some difference in bearing caps, and you need to make sure the ones you have fit right. The edge of the cap should snug against the brake backing plate and there should be no movement of the bearing outer race inside the cap with the cap bolts snugged down. The axle shaft should have some movement inside the bearings with the cap on but the drum off. With the drum on and the axle nut snug, there should be no end play in the axle. _________________ Richard
SoCalBajas Member
