escape42 Samba Member
Posted: Sun Oct 19, 2014 11:49 am Post subject: Codes from 2003 VW Beetle 2.0L manual transmission |
I've got a 2003 VW Beetle 2.0L manual transmission that I picked up a couple months ago. After driving it for 50 miles the check engine light when on. I scanned it with a VAG-COM and got the codes below.
I reset the codes and drove the car for another 800 miles before the check engine light came on again. The car runs fine. The only notable exception is that sometimes when I'm driving on the highway in 5th gear the engine seems to slow down for a few seconds before it picks back up and it kinda jerks when it picks back up.
I climbed under the car and was able to locate the Engine Speed Sensor close to the base of the oil dipstick. I may be able to disengage the harness and get to the bolt without taking anything off. I'm wondering if replacing the Engine Speed Sensor (CKP?) would solve the P0321 or if there's anything else I should check first.
I'm wondering if anyone has seen this before or might have some wisdom they can share.
Much appreciated!
e
VAG-COM Version: Release 409.1-S
Chassis Type: 9C - VW Beetle
Scan: 01,02,03,08,15,17,19,26,35,46,54,56
Address 01: Engine
Controller: 06A 906 032 MG
Component: 2.0l R4/2V G 4633
Coding: 00001
Shop #: WSC 00066
3VWBK21C93M400306 VWZ5Z0B4061031
1 Fault Found:
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00066
No fault code found.
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1C0 920 921 C
Component: KOMBI+WEGFAHRS. M73 V08
Coding: 03232
Shop #: WSC 00000
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN V082
Coding: 00006
Shop #: WSC 00066
Address 46: Central Conv.
Controller: 1C0 959 799 G
Component: 2K Komfortgerát HLO 0004
Coding: 00064
Shop #: WSC 00066
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
End
Beeble1 Samba Member
Joined: August 14, 2012 Posts: 577 Location: Manteno, Illinois
Posted: Sun Oct 19, 2014 1:58 pm Post subject: |
You're in the wrong forum. Try this one.
http://www.thesamba.com/vw/forum/viewforum.php?f=11 _________________ Beeble1, ‘73 Super (o\_|_/o) 1600cc w/ Dealer A/C
Beeble2, ‘13 Beetle 2.5L Daily Driver
Dealership items from Bishop-Wayne Volkswagen & Turner Volkswagen in Kankakee, IL wanted |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Oct 20, 2014 7:22 pm Post subject: |
That is the crank sensor, it will keep the motor from running, as the ecu doesn't know the crank is turning when that sensor fails. For the Module coded incorrectly, use the coding helper to set it correctly. |
