1980 vw rabbit 1.6l alternator wiring diagram.
Forum Index -> Water-cooled VW Share: Facebook Twitter
winchin73blazinbaja
winchin73blazinbaja is offline
PostPosted: Sun Oct 19, 2014 5:54 pm    Post subject: 1980 vw rabbit 1.6l alternator wiring diagram. Reply with quote
ok I have a 1.6l gas engine out of a 1980 rabbit. i have everything working and wired properly besides the alternator. any one have any idea which posts are supposed to run to where? have hooked it several ways to no avail.
ps2375
ps2375 is offline
PostPosted: Mon Oct 20, 2014 7:09 pm    Post subject: Reply with quote
Alt wiring would be the same. The alt could be made by either Bosch(most likely) or Motorola. All you have is power and exciter. If the Alt has 3 terminals for the plug, the 2 large ones are power out and the small one is the exciter.
winchin73blazinbaja
PostPosted: Tue Oct 21, 2014 6:49 am    Post subject: Reply with quote
mine is a motorola. it is not actually in a rabbit i have the motor installed in my 74 baja bug. so the small post will run from the battery to the post. the two large posts will run together and back to the battery? (all the positive side of the terminal obviously
ps2375
ps2375 is offline
PostPosted: Tue Oct 21, 2014 7:24 am    Post subject: Reply with quote
You need the exciter wire hooked up correctly to get the alt to put out voltage. Try google or looking at the wiring diagrams for nearly any car.
winchin73blazinbaja
PostPosted: Tue Oct 21, 2014 7:37 am    Post subject: Reply with quote
i have googled it for this alternator. cannot find anything. or for vw rabbits 1.6l gasoline engines. i find plenty for the diesel alt which has a completely different post layout. your answer should be enough for me to work off of. i have the exciter wire hooked up properly i just need to run the other two posts back to the battery and the post located lower on the alt will run to my charging indicator on my dash.
ps2375
ps2375 is offline
PostPosted: Tue Oct 21, 2014 8:01 am    Post subject: Reply with quote
Not sure what the third terminal is for. When I get home in a couple of days, I can check my Bently Manual.
winchin73blazinbaja
PostPosted: Tue Oct 21, 2014 8:05 am    Post subject: Reply with quote
that would be great! it has one labeled D+ (the small one), two labeled B+ (the big ones) and one that is down lower that is a small post by itself.
ps2375
ps2375 is offline
PostPosted: Tue Oct 21, 2014 8:53 pm    Post subject: Reply with quote
D+ is the exciter, B+ is battery/output. If the one by itself is a threaded stud, it is just a stud for the plug retainer or a ground, depending upon where it is on the alt.
winchin73blazinbaja
PostPosted: Wed Oct 22, 2014 2:22 am    Post subject: Reply with quote
I hooked up to d+ and nothing happened Hooked into the small plug on the bottom and had it not charging still. Grounded the alt an now have a weak charge will swap the power wire back to d+ and see if it charges better
ps2375
ps2375 is offline
PostPosted: Wed Oct 22, 2014 7:23 pm    Post subject: Reply with quote
Have you had alt tested? Could also be a faulty voltage regulator.
winchin73blazinbaja
PostPosted: Thu Oct 23, 2014 5:38 am    Post subject: Reply with quote
i beleive it is running now. Smile swapped the exciter wire to the small post up top and the problem is fixed. i believe. i will hook my multimeter up to it tonight when i get home. the problem I was having is that the alt does not close the circuit until it is in rotation i was testing the posts with the ignition turned on and not started. it was a rookie mistake. Razz
ps2375
ps2375 is offline
PostPosted: Thu Oct 23, 2014 2:26 pm    Post subject: Reply with quote
A minor over-sight. LOL
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
