C_reed Samba Member
Posted: Sun Oct 19, 2014 8:04 pm Post subject: Ghia will not turn over - Suggestions? |
Hi all,
Today I went to start up my Ghia and nothing. Just silence. The 2 red lights on the speedometer were on (oil and generator) and the headlights and inside lights as well as radio works fine.
Pulled out all my books and read about this. two options.
-Ignition Switch
-Starter/Solenoid
I connected a extra ignition I had and got the same lack of engine turning over.
So I assume its a Starter issue. Is their anything else I am missing?
Whats the easiest way to test my starter? I am new to starter issues.
I won't be able to work on this tell next weekend but thought I would spend the week researching and maybe picking up a starter.
thanks everyone for the help and time.
Cheers
-chris |
-Zodiac- Samba Member
Joined: September 22, 2014 Posts: 782 Location: Pensacola/milton, florida
Posted: Sun Oct 19, 2014 8:24 pm Post subject: |
http://www.vw-resource.com/starter.html
Read this, in the 'big click' section it shows you how to test the stater solenoid. _________________ 1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives. |
squonk Samba Member
Joined: August 13, 2011 Posts: 257 Location: Upstate New York
Posted: Mon Oct 20, 2014 9:42 am Post subject: |
One other possibility, especially if you have anything stowed beneath the rear seat, or had done any work under there before the problem showed up, is the rectangular plastic connector that, at least in my car, transits beneath the driver's side of the rear seat. I knocked that loose one day when routing the decklid release cable, and it gave me the same symptom. Probably a long shot, but an easy thing to check off the list. _________________ '71 Ghia cabriolet |
mountainkowboy Samba Member
Posted: Mon Oct 20, 2014 12:55 pm Post subject: |
My Vert did that......the starter sense wire fell off the starter somehow. Tightened the spade and put it back on the starter.......fixed. _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
C_reed Samba Member
Posted: Mon Oct 20, 2014 6:13 pm Post subject: |
Thanks! I will look under the seat and under the car to see if any wire has come loose. There hasn't been any work done to the seats or underside as far as I know. That would be cool if its just that.
if not I will test the starter/solenoid.
cheers all. thanks |
C_reed Samba Member
Posted: Tue Oct 21, 2014 6:44 pm Post subject: |
Hi all
So I looked under the seats and no wires at all and nothing un plugged.
But I am not getting a "Click" like most sites say when you have a bad solenoid. So i measured the Voltage across the battery and it said 10.3 V.
I assume thats low and thats probably the problem. From a site I read that the voltage should be 14 or so on a full charge battery (but I don't know how that can be if its a 12V battery).
Do you all think its just a low battery? I don't have a battery tester but can pick one up.
I do not know how old the battery is. It was in the car when I got it in 2008.
thanks all
-chris |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Tue Oct 21, 2014 7:23 pm Post subject: |
C_reed wrote: |
Hi all
thanks all
-chris |
Do you have a plastic fuel filter in the engine bay?
Maybe that's your problem. |
Posted: Tue Oct 21, 2014 7:43 pm Post subject: |
If you've been driving it often than the battery should be charged enough for it to at least try to turn over. If you think the starter is messed up go whack it with a hammer. _________________ 1973 karmann ghia - current, not the last VW.
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Tue Oct 21, 2014 7:48 pm Post subject: |
ignore iowegian
you need a test light or a volt meter and a friend to turn the key. Make sure it is out of gear and ebrake is on. Climb under there and see if any volts are getting to the solenoid when the key is turned. Even with low voltage the solenoid still clicks. If there is voltage to the solenoid you can pull the starter and take apart and clean up the solenoid and put it back together. It's the permanent fix to wack it with a hammer. |
Zeen Samba Member
Joined: July 24, 2004 Posts: 1308 Location: The Sunny Part of Michigan
Posted: Tue Oct 21, 2014 9:16 pm Post subject: |
Ignore ptjjb after you ignore iowegian.
Until you get 12+ volts from the battery, further testing is a waste of time. Whenever there is a battery or charging problem, and the battery is more than four years old, the first step is buying a new battery. You've had yours six years, and the P.O. probably didn't replace it immediately prior to selling you the car.
But if you're an inveterate cheapskate like so many VW owners, at least verify it can hold a charge before wasting any more time.
Then move the fuel filter. _________________ The consequences of your decisions should not be confused with fate. |
Posted: Tue Oct 21, 2014 9:28 pm Post subject: |
from cheap vw owner, throw your battery in another car to charge it _________________ 1973 karmann ghia - current, not the last VW.
C_reed Samba Member
Posted: Tue Oct 21, 2014 10:40 pm Post subject: |
Thanks all for the advice
-c |
c21darrel Samba Member
Abscate Samba Member
Posted: Mon Nov 03, 2014 5:19 pm Post subject: |
10.3 volts for a battery is very low and won't pull in the solenoid, so you won't get a click. It's definitely a discharged battery and probably a bad battery too. _________________ .ssS! |
