CnfsdWhtGuy Samba Member
Posted: Sun Nov 09, 2014 3:39 pm Post subject: |
Sorry havent been on since you told me to get a dwell meter. Anyway its on its way now. So you think i dont have good compression? To be cleae it starts easy and as long as the choke is on it runs like a charm. As soon as it warms up and the choke opens it will not stay running. Doesnt matter what step its on. |
Posted: Sun Nov 09, 2014 3:43 pm Post subject: |
Also i sprayed starter fluid around the carb and where the intake meets the head but it did not pick up at all. |
Kmolenda Samba Member
Joined: June 18, 2013 Posts: 309 Location: Cottage Grove Mn
Posted: Sun Nov 09, 2014 4:47 pm Post subject: |
Sounds like its time to rebuild the carb. 20 bux for the kit and an hour or so of your time. Choke on - run good. Choke - off it dies, result of too much air not enuf juice... Mine did the same thing after a 10 year sit. My buddies bug after a 3 year sit. |
Posted: Tue Nov 11, 2014 2:34 pm Post subject: |
Also there seems to be a slight leak right here. Its wet each time i try and run... could this be something? Can i seal this? |
c21darrel Samba Member
Posted: Mon Nov 17, 2014 6:41 pm Post subject: |
Ok. I jb welded that spot, and I had a friend come over and pressure test my motor. I think we may have spotted an issue. the number 4 plug has no pressure at all. the others go up to 100 but rest at 90lbs per port. I was told maybe a stuck valve? What do you think? |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Mon Nov 17, 2014 8:52 pm Post subject: |
pull the valve cover and hand crank the motor. watch for rocker arm movement on that cylinder |
Posted: Fri Nov 21, 2014 12:44 pm Post subject: |
What does this tell you? It looks like they valves are going up and down. port in questions are the valves on the right. |
Posted: Fri Nov 21, 2014 2:05 pm Post subject: |
It is built into the carb. it was coming out though so I JB welded it in place. With zero compression on that valve will the oil help? I would like to address this first if possible. |
Posted: Fri Nov 21, 2014 10:44 pm Post subject: |
Had a friend help me with the compression test. We did it twice... that ones not working. Will try mmo and update. |
Posted: Mon Nov 24, 2014 2:22 pm Post subject: |
What am I looking for on the rocker arms and push rods? Are these inside the valve cover as well? Sorry in advance for my lack of any useful knowledge. |
-Zodiac- Samba Member
Joined: September 22, 2014 Posts: 782 Location: Pensacola/milton, florida
Posted: Mon Nov 24, 2014 3:30 pm Post subject: |
And you you see this than you take off the assembly to make sure that your pushrod isn't bent. _________________ 1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives. |
Posted: Mon Nov 24, 2014 4:33 pm Post subject: |
I do have access to the idiot book. It has been sitting in my garage... Was lent to me by Asesapie. I should probably read that... Up until now I just didn't really have an idea of what my problem was. Now would probably be a good time to check it out. |
Posted: Tue Nov 25, 2014 9:34 am Post subject: |
Can you see from the Valves video I posted above if you see anything. It does not look like your picture at all. |
