frenzydude Samba Member
Posted: Mon Oct 20, 2014 2:54 am Post subject: Beetle seat compatability |
Hi. Can anyone tell me if the front and rear seats from an oval will fit into a 63 bug without any modification? |
anthonycanchola Samba Member
Joined: January 06, 2014 Posts: 122 Location: San Pedro, CA
Posted: Mon Oct 20, 2014 3:10 am Post subject: |
Try it. _________________ 1981 Vanagon (traded)
1967 1776cc
2332 coming soon |
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Mon Oct 20, 2014 3:33 am Post subject: |
Front seats - yes
Rear seat - I'm not sure _________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
Posted: Mon Oct 20, 2014 6:30 am Post subject: |
anthonycanchola wrote: |
Try it. |
Gotta buy it before I can try it. |
Brian Samba Moderator
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon Oct 20, 2014 7:07 am Post subject: |
Yes...and no...
Depends on the year of the Oval..
VOLKSWAGNUT wrote: |
RareAir wrote: |
There are basically only 4 styles of seat rails (not including the standard type that utilize wing nuts to hold down the seat)
1950-55 are straight and have 2 tabs for adjustment
1956-70 "L" style
1971/72 "T" style
1973-79 Tripod style
DrDarby wrote: |
Up to 1970 uses one style seat rail, 1971 & 1972 use another style and the seats wont interchange.
1973 then got the tri-pod set up for safety and completely different seats.
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
bdub475 Samba Member
Joined: April 05, 2009 Posts: 577 Location: Los Lunas, New Mexico
Posted: Mon Oct 20, 2014 10:57 am Post subject: |
56 and up front should fit. The rear will fit but i believe the rear seat back will lean back too far or it may be the other way around. |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Thu Mar 21, 2024 7:10 am Post subject: |
Brian wrote: |
I think fronts are compatible from '53? to '70? |
After recently getting my 67 bug up and running I’m not sure I want to stay with the aftermarket seats I installed. With the car lowered and with the 18”wheels I don’t think it will make for a very comfortable long distance cruiser. These seats have very little cushioning which means I feel every little bump thru the seat of the pants.
So now I’m thinking about installing the Empi or Bugpack lowback reclining seats to be reupholstered in the matching VW Gti material or stock lowbacks and get the seat covers from SewFine with my material. My question is if I go with stock what yr? up to 67 will be a direct bolt-on to my factory sliders.
Thanks |
