Vanagonzo Samba Member
Posted: Mon Oct 20, 2014 1:55 pm Post subject: Equivalent VW Automatic Transmissions for Vanagons |
Hey all I have a 1990 Vanagon with a blown 3 speed automatic transmission. I am trying to find a used one at a wrecking yard (not an easy task) to get it back on the road for as cheap as possible. I have heard that some makes and models of Audi and VW have automatic transmissions that will bolt strait up to the Vanagon automatic differential. I only want to swap the guts ie: the automatic transmission portion only, not the diff/transaxel or any other parts of the drive train if possible. Does anyone have a list of the year make & models of VW or Audi autos that have easily swappable automatic transmissions for Vanagons? If I had such a list I could broaden my search at regional junkyards. Also is there any additional checks I should do with my or on the "donor" auto-tranny to make sure it will work? Any information would be super helpful to me and probably to future automatic van owners for generations... |
madspaniard Samba Member
Posted: Mon Oct 20, 2014 2:04 pm Post subject: |
Audi 5000 turbo, great info in link below
http://www.thesamba.com/vw/forum/viewtopic.php?t=253381&highlight=campground
itzdshtz wrote: |
basically all the 5 cyl turbo engines in the 5000/100/200 had the stronger 4 pinion planetary sets in there up to 1991, after that they got the electronic 4 speed automatics which are totally different.
All the non turbo engines came with the 3 pinion planetary transmissions.
The early V8 Audi's were all quattro's and used a different transmission.
Herman |
_________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Mon Oct 20, 2014 8:27 pm Post subject: |
Basically any VW/Audi from the late-70s to the early 90s with the 3-speed auto trans. Also any Porsche 924 or 944 auto trans. The Audi turbo and Porsche 944 have the stronger internals. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
danfromsyr Samba Member
Posted: Tue Oct 21, 2014 8:12 am Post subject: |
these are fairly simple transmissions, what is yours doing or not doing?
when they say any they mean any automatic from VW/Audi from 1976-1992 is essentially the same. but there are 3 different transmission cases depending on trans cooler or dipstick location.
you very well may have to remove the guts from the good to the bad to exchange them over..
and by case i mean the transmission portion that mates to the differential portion. the 2 of these make up the complete transaxle.
unless you are comfortable with the internals of an automatic transmission there really isn't any cheap or free lunch..
the 5000 turbo link provided above is a very good idea of the work involved.
FWIW the vanagon AT should be able to be rebuilt by any transmission shop who can/will rebuilt a rabbit cabriolet (81-92) automatic. parts/labor should be under $1k but your local and limited shop resources will greatly impact the overall costs.
best of luck. _________________
Abscate wrote: |
kbeefy Samba Member
Joined: March 10, 2006 Posts: 600 Location: Central Oregon
Posted: Tue Oct 21, 2014 10:49 am Post subject: |
Saw your post on CL, I'm on Oahu right now.
Good luck! _________________ 86 syncro CHC, NorthWesty subbie 2.5, decoupler, locker, custom interior, 225/75r16 Duratrack's on CLK's, Toyo cabin heater, ARB fridge, 300w Zamp Solar, Gowesty bumpers/skid/rails, Fiama awning
'86 Syncro Westy. Stock for now.
2000 F350 7.3 CC LB 11' Northland Cabover
2006 Subbie OBXT
2002 Tacoma DoubleCab 4x4
1969 Mustang Basket Case 351c/FMX/9
http://kbeefy.blogspot.com/ |
