CatLady Samba Member
Posted: Mon Oct 20, 2014 3:05 pm Post subject: CatLady '76 Riviera |
Hey Samba Friends-
I took my bus to another air cooled mechanic that was recommended and a lot easier to get to than the first one I went to. A couple of hours after I dropped it off I got a call. The guy said that the #3 cylinder head dropped (on the exhaust seat, I think he said.) He said that I needed a engine rebuild.
The quote he gave me was $3800-4800. He said that they use all new parts except for the cranks, rods and fly wheel.
Another thing that happened is that the oil light came on when the engine would idle. (Only when it idled. It was fine when it was running. Last time I checked the oil it was fine and there were no leaks under the bus.) It was fine on the way there but started it on the way back to my kitchen.
I just got back and haven't researched much here or on ratwell. (Figured it out. I just noticed the "title only" option for searches. Much better.)
Thank you for all your help while I've been figuring this out. _________________ '76 Riviera
2.0 Liter
FI
Type 4
'63 Bug
1600 cc, 12V
Restored interior, OG paint
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Mon Oct 20, 2014 3:12 pm Post subject: |
EDIT: misread part of OP's original post!
Without knowing the exact nature of your engine's defect beyond what he told you, it sounds like he is selling more work than may be necessary. Having a dropped valve seat would not absolutely require a full on rebuild of the entire engine, but certainly would likely be cause for a deep inspection of the case for fragments and measuring.
Sounds more like a quick diagnosis and remedy without a more thoughtful approach. |
Posted: Mon Oct 20, 2014 3:15 pm Post subject: |
Wasted youth wrote: |
I edited it a bit. I changed "save for" to except. Does that make more sense? _________________ '76 Riviera
2.0 Liter
FI
Type 4
'63 Bug
1600 cc, 12V
Restored interior, OG paint |
Posted: Mon Oct 20, 2014 3:24 pm Post subject: |
No, you're good. I simply needed to slow down and read the statement.
Did you drive your bus to the mechanic under its own power, or what? |
Posted: Mon Oct 20, 2014 3:30 pm Post subject: |
Yes, I drove it under it's own power though sometimes it went very slow. Like 10 mph up a very slight incline. I was super popular with the cars behind me.
Google tells me that the oil light coming on is a sign that the main and rod bearings could be going. _________________ '76 Riviera
2.0 Liter
FI
Type 4
'63 Bug
1600 cc, 12V
Joined: January 01, 2007 Posts: 16861 Location: sticksville, ct.
Posted: Mon Oct 20, 2014 3:33 pm Post subject: |
sorry. any guy worth his weight would do a full teardown anyway. to band aid a repair like that for a customer is suicide.
for your own car, doing your own work? go for it. but if you have to stand by your work for a customer, it's all or nothing.
to open that engine to "inspect" and "rebuild" has given GEX the reputation they deserve. stuff wears out.... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Mon Oct 20, 2014 4:04 pm Post subject: |
Any way you slice it, it's going to be expensive. Type 4 parts are more expensive and there are fewer choices as well. I certainly don't advocate the thought process of 'just change out the bad head!' that often happens. But I do find the blanket notion of 'it needs a complete rebuild' without more investigation a little alarmist.
Who knows what else is in there? Maybe it needs even more machine work? Maybe the cost would exceed what he told you... maybe you're better off with a long block.
Hell, I wasn't there. Just speculating as a detached fourth party. |
Posted: Mon Oct 20, 2014 5:57 pm Post subject: |
CatLady wrote: |
I could put the insurance $ into the bus engine and make it my new daily driver. |
bad idea. if you need a mechanic now, wait till you d/d a bus. save some money for a bus pass.
I d/d my buses when the weather allows. never really had an issue, but I do my own work too. when it 300* outside and I have the kid, it's the Audi's turn to run.
in my opinion, you need to buy a reliable d/d. not saying your bus couldn't be, but if you are having sticker shock now...just wait _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Mon Oct 20, 2014 9:57 pm Post subject: |
Find someone through your local VW club who will check your engine out for you, or check the air cooled rescue list for someone in your area. Someone who is familiar with a Type 4 fuel injected engine may see something simple that a shop might have missed. |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Tue Oct 21, 2014 3:46 am Post subject: |
Or see if you can source a working t4 motor locally that would get you back on the road. Usually those motors are 600-1500. Of course if you cant see it run first its definately buyer beware _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Tue Oct 21, 2014 9:08 am Post subject: |
As was mentioned above, you should find someone local that is willing to help you (that also knows type 4's, and doesn't have financial gain in mind) and get a better idea of what you need for that engine.
If it needs a rebuild, you should consider calling Adrian, at http://www.headflowmasters.com/index.html _________________ '76 Deluxe Campmobile |
Posted: Wed Oct 22, 2014 9:04 am Post subject: |
Wildthings wrote: |
Thank you for the suggestion. I reached out to one guy on the rescue list who sounds like he really knows his stuff. I found another guy on another forum. I'm waiting to get approved so I can contact him. _________________ '76 Riviera
2.0 Liter
FI
Type 4
'63 Bug
1600 cc, 12V
Posted: Wed Oct 22, 2014 9:06 am Post subject: |
poptop tom wrote: |
If it needs a rebuild, you should consider calling Adrian, at http://www.headflowmasters.com/index.html |
Thanks for the rec! _________________ '76 Riviera
2.0 Liter
FI
Type 4
'63 Bug
1600 cc, 12V
Posted: Wed Oct 22, 2014 9:08 am Post subject: |
aerosurfer wrote: |
Or see if you can source a working t4 motor locally that would get you back on the road. Usually those motors are 600-1500. Of course if you cant see it run first its definately buyer beware |
I haven't given them a call yet, but I live near Busted Bus and they seem to have good reviews on here. Thanks for the idea! _________________ '76 Riviera
2.0 Liter
FI
Type 4
'63 Bug
1600 cc, 12V
Posted: Wed Oct 22, 2014 9:10 am Post subject: |
skills@eurocarsplus wrote: |
CatLady wrote: |
in my opinion, you need to buy a reliable d/d. not saying your bus couldn't be, but if you are having sticker shock now...just wait |
oy... I got the bus for my business so it does need to be out and about for it to be effective. I don't drive a ton. I think I put about 6,000 miles on my old car last year. I have a cargo van too, so I do have backup transportation. _________________ '76 Riviera
2.0 Liter
FI
Type 4
'63 Bug
1600 cc, 12V
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Wed Oct 22, 2014 1:00 pm Post subject: |
I assume your mechanic did a compression check and may have looked at the valve stem height to say that the valve seat dropped in #3. That's what happened to this guys bus.
He was on a cross country trip and kept driving with the bad cylinder. When he got here I helped him pull the engine and then he took the heads to Adrian for rebuild ($800). The guy (Mike) put it all back together but he found low compression in #3 cylinder. Turns out that this was caused by driving it with zero compression because of the valve seat but then wearing out the rings because he left the injector connected. So if you keep driving it much pull off the connector to that injector at least. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
richparker Samba Member
Joined: November 24, 2011 Posts: 6981 Location: Durango, CO
Posted: Wed Oct 22, 2014 2:40 pm Post subject: |
Have you tried Painters Grinding there in Denver. I know they do T1 engine but I'm not sure about t4s. Worth a shot. There's KCW in GJ also. Curtis4085 has had a good amount of dealings with Painters. Maybe you should send him a PM. I've never used them, I just know they are there. Good luck. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
SGKent Samba Member
Posted: Wed Oct 22, 2014 3:40 pm Post subject: |
if it dropped a valve seat the damage will be easy to see from the outside. The valve stem will be a different height, and there will be little to no compression on that cylinder.
The bus should not be driven. You could use someone like Colin (Amskeptic) to help fix it but he is thru with that part of the country for the year.
if that happened to a bus I was responsible for I would mentally know that the bus would be down for at least a month. And, when I put it back together everything on that new motor would be right, not just the original issue fixed.
It is not a daily driver candidate. It will cost you much more to fix than any insurance company will cover if you use it as your primary car for one. For two it is a high theft vehicle if you start leaving it parked in places you can't see it like movie theater lots etc. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
Posted: Wed Oct 22, 2014 4:06 pm Post subject: |
I agree with others that cash put into a daily will pay off better in the long run. Yes, quality parts for a t4 are right about twice that of a t1. Accept no band-aids. Do it all or none if you decide to try to make it your dd.
To give you a reference, I have over $8000 in my t4 engine (now that same engine is $20,000 turnkey) and I did all but the machine work myself. Sure, it's not stock but I don't really see how you could even squeak by on <$5000. New parts and "new parts" are two different things. Get some references on the shop and check them.
Buying a used engine....meh. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
