1966kghia Samba Member
Joined: October 20, 2014 Posts: 23 Location: Ontario, Canada
Posted: Mon Oct 20, 2014 4:21 pm Post subject: Happy to be an airhead again..66 ghia |
Was looking for the newbie introduction forum to say hi but couldn't find it. So hi from Toronto, Canada!
Picked up a 1966 Ghia this weekend and am looking forward to getting dirty getting it road worthy again and interacting on thesamba. I'll see if I can attach a pic.
Originally Bermuda Blue.
Brakes should be good, PO said he did them, I'll double check.
Clutch is frozen after sitting 20 years, hope to free them up.
Pans and battery tray need replacing, and a hole or two around the windows.
Etc...
Gonna be fun! |
John Miller Samba Member
Joined: October 16, 2004 Posts: 735 Location: Elizabethtown KY
Posted: Mon Oct 20, 2014 5:03 pm Post subject: |
Welcome, eh. _________________ The 68 Ghia
The 62 Beetle
slafa wrote: |
Any suggestions will be appreciated even if they suck and are stupid. |
Posted: Mon Oct 20, 2014 5:53 pm Post subject: |
John Miller wrote: |
Welcome, eh. |
Clever! But thanks! |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Mon Oct 20, 2014 7:29 pm Post subject: |
Welcome to the Addiction |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
Posted: Mon Oct 20, 2014 7:53 pm Post subject: |
Welcome aboard! The Samba is an addiction, just the same as these damn cars! 66 is a great year! Does yours still have the dash trim? _________________ Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807 |
Posted: Mon Oct 20, 2014 8:08 pm Post subject: |
Thanks for all the warm welcomes.
I may have the dash trim, need to dig through the boxes of spares. One piece is still in place. I'm so new to this, but I believe the dash trim is about an 1" wide, right? BUT, someone trimmed the dash to fit a modern stereo in at some point. That's upsetting.
Gonna be some fun times ahead! |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Tue Oct 21, 2014 7:59 am Post subject: |
Just a tip you probably already know, but Don’t throw anything away! At least not until you have a suitable/usable replacement in hand.
The dash trim is a one-year only item, as is the emergency flasher and both are rare and expensive. Even if your trim is in poor shape with pieces missing, hold on to it as you may have to fix it or use it to make a replacement. There was someone here doing aluminum repros for about $200 but I don’t think they are available anymore.
Post more pics! _________________ Air does not freeze. Air does not boil.
Posted: Tue Oct 21, 2014 5:36 pm Post subject: |
I have no plans to toss anything yet, I have a good amount of garage space.
My Ghia project is going to be a weekend project at my shop 2 hours out of Toronto. I will try to get some quality pics next time I see her.
I sure hope that dash trim will reveal itself in one of the boxes. I haven't a clue where the emergency flasher is even located. I skimmed the online owners manual and couldn't find reference to it either.
Am I right that the lighting in this pic is wrong? The engine is running with the lights on, but the brakes are not depressed. Aren't the running lights at the bottom of the tail lights and brake lights the centre?
Posted: Tue Oct 21, 2014 5:51 pm Post subject: |
A few significant rusty spots beyond the pans and battery tray.
Posted: Tue Oct 21, 2014 7:04 pm Post subject: |
sputnick60 wrote: |
The flasher is between the Lights and Wiper controls, just below the trim.
I'm not near the car now, but I think I would've recalled that knob (very flashy ). In your pic, is that the ignition below the speedo and dash? My ignition is on the right side of the steering wheel in the dash.
WRT the flasher, would there be variations from country to country? I believe my originated from the US.
Thanks Nicholas. I'm excited to dig deeper this weekend. |
Posted: Tue Oct 21, 2014 7:26 pm Post subject: |
1966kghia wrote: |
In your pic, is that the ignition below the speedo and dash? My ignition is on the right side of the steering wheel in the dash. |
That photo happens to be for a '66 cabriolet and the lock you see for the front trunk release. A coupe has an ivory coloured pull for that function and in the same location. You can lock the doors and close the windows in a coupe but with the top down the villains needs to be locked out of a cabriolet's trunk. Karmann came up with this which has been a cabrio feature for every model year since the start.
The ignition key switch is as you describe, inboard of the steering wheel, usually. However I have seen photos where cars with a combination gear-lock and ignition key-switch set up have the ignition switch by the base of the gear lever and the emergency flasher knob where the ignition key is normally placed. Plainly not the case with your car.
1966kghia wrote: |
WRT the flasher, would there be variations from country to country? I believe my originated from the US. |
There are variations. The US versions have the flashers and I think that is stipulated in the US design rules for that year. The European versions sometimes do and sometimes don't have the flashers. I think the flashers were offered as an option back in the day and I think the photos of the cars described earlier with the gear lock and flasher in the ignition hole are european delivered cars.
If you need to get a replacement flasher relay, Wofsburg west have a repro version which has modern innards but looks the same outside. However it is designed to run on 12Volts. Otherwise, to find a 6 volt version you'll need to search the samba advertisements for a 6 volt "9 prong box" which do show up from time to time, but come with the risk of being a dud. Not many people know how to , or bother to test them.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
hiho Samba Member
Joined: August 18, 2005 Posts: 33 Location: Beaverton, Ontario
Posted: Tue Oct 21, 2014 8:08 pm Post subject: |
I bought a 66 2 weeks ago. im in toronto as well and doing similiar repairs....hope we might be able to help each other out.
heres my dash, I do have all the trim but started removing it in an effort to fix the dents and possibly try and reproduce a set or 2.
im in the west end, drop me a line!
[/img] |
Posted: Wed Oct 22, 2014 5:25 am Post subject: |
1966kghia wrote: |
For some reason, the 66 owners manual appears to be euro only. (No emergency flasher, no North American spec bumpers). I went looking for one for this side of the pond, but there wasn't one.
Car doesn't look too bad, though once you start in I'm sure you'll find a few unhappy surprises. Any plans to make it a runner to enjoy it a bit before you dig in? Or is it too far gone for that? _________________ Air does not freeze. Air does not boil.
Posted: Wed Oct 22, 2014 11:58 am Post subject: |
hiho wrote: |
I'll shoot out a PM. Would be great to have a fellow enthusiast near, especially with the same year Ghia! |
Posted: Wed Oct 22, 2014 12:01 pm Post subject: |
sputnick60 wrote: |
I have 3D scans of the trim set. If you wish you can order 3D prints of them. With those you only have to chrome plate them. |
3D printing is so amazing! I will def keep that in mind. This weekend, I'm going to go thru my boxes and see what I still have. |
Posted: Wed Oct 22, 2014 12:04 pm Post subject: |
bobnorman wrote: |
Car doesn't look too bad, though once you start in I'm sure you'll find a few unhappy surprises. Any plans to make it a runner to enjoy it a bit before you dig in? Or is it too far gone for that? |
I would love to drive it for a while so I will try to get her on the road soon. The heater channels appear solid, but new pans are in order. But the body appears solid.
Going to snap more pics this weekend.
Thanks for everyone's help and suggestions! |
