RedHeadedJosh Samba Member
Joined: June 04, 2011 Posts: 184 Location: Daphne, AL
Posted: Mon Oct 20, 2014 6:18 pm Post subject: Traded my 83 honda odyssey for a 72 super beetle |
before wash
after wash left is clean and right is before.
some one please tell me what carb this is _________________ 72 super beetle resto
71 westy Resto ( http://www.thesamba.com/vw/forum/viewtopic.php?t=477613 )
Don't tell me what I can and can't do! |
luvtheeluvbug Samba Member
Joined: January 06, 2013 Posts: 288 Location: Sonora, Ca
Posted: Mon Oct 20, 2014 6:24 pm Post subject: |
It's a dual barrel Zenith 32 NDIX Carburetor. I think they're from Porches. I have one on my baja bug and it really packs a punch! _________________ Fahrvergnugen/ far-fair-gnu-ghen/ Description of a pleasurable sensation experienced when a car and it's driver are in mutual harmony; A unique driving experience; Pleasure; Satisfaction; A feeling experienced by Volkswagen drivers. |
Posted: Mon Oct 20, 2014 6:57 pm Post subject: |
Thanks luvtheeluvbug, they owner said they thought it was from a Porsche but really wasn't sure at all. i don't know if there are any modifications for it?? the springs are kinda rigged up on it. i need to tune the engine and clean her up before i can really open her up. [/quote] _________________ 72 super beetle resto
Posted: Mon Oct 20, 2014 8:08 pm Post subject: |
Someone custom made a manifold for my carburetor which is significantly taller and forced me to run an S curved guide tube through the fan shroud to aline the throttle cable correctly. It looks like your manifold is shorter which is nice. Also, as you probably already saw, it's a manual choke. You should have no problems getting parts for it. _________________ Fahrvergnugen/ far-fair-gnu-ghen/ Description of a pleasurable sensation experienced when a car and it's driver are in mutual harmony; A unique driving experience; Pleasure; Satisfaction; A feeling experienced by Volkswagen drivers. |
Posted: Tue Oct 21, 2014 7:25 pm Post subject: |
So my blinkers are acting up so i started playing with the bulbs thinking that maybe the bulbs were loose or there was a short in the cables, come to find the relay being bad about a hour of tinkering, so go up to the local advance auto and cross it to what they have in stock and plug it in. also got oil, gasket, and spark plugs, 10w-50 and i presume it takes 3-4 quarts and don't know the plug gap yet. I get home and plug in the relay and the blinkers work great, i start seeing smoke and shut the electrical off. Turn to find out the fuse blew and i guess i wired the light back wrong ??? I don't know, so no more brake lights for me .... don't know anyone who sells the fuses local. The kicker is my blinkers work fine still but now my tail lights don't work so no stoping for me only turns... first screw up on the bug _________________ 72 super beetle resto
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Tue Oct 21, 2014 7:36 pm Post subject: |
Odd, my FLAPS (Friendly local auto parts store), also an Advanced, has the fuses. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8689 Location: Sunset, Louisiana
Posted: Wed Oct 22, 2014 1:50 pm Post subject: |
Does anyone know a good wording diagram for my tail lights? I'm going so see if it's the taillight wired wrong can it cause the fuse to blow? _________________ 72 super beetle resto
toddb_67 Samba Member
Joined: November 28, 2003 Posts: 1313 Location: Hansville, WA
Posted: Wed Oct 22, 2014 7:58 pm Post subject: |
thanks for the reply man, ill try it out tomorrow, i hate electrical and especially diagrams _________________ 72 super beetle resto
Posted: Fri Oct 24, 2014 4:03 pm Post subject: |
Non of my wires are the right colors on my bug.... I got the blinkers to work but now when I press the brakes the tail lights dim... Help please _________________ 72 super beetle resto
Posted: Wed Oct 29, 2014 7:00 pm Post subject: patch pan under battery |
SO to find out it looks like some one welded in a pan for the battery at one time so it wouldn't fall threw the floor . So tuesday i got my package of seals and misc parts along with the floor pan from Jbug, very nice quality and ships fast! so time to cut and FABRICATE!!! best part about rusty and old vws!! the beetle looks like childs play vs the bus. so here is my progress.
2 10mm bolds and a screw to remove the y pipe(which you need jacks or a lift to do, and move everything out of da way.
Most of the rust is centered around the tray and creeping towards the heater channel and the low spots of the floor boards and rockers, surprisingly the drivers side is solid.
step 2: when theres rust cut it out!! rust is cancer for VWs
I cut enough to fit whole half panel in and some to over lap under the passenger seat for support, even not welded the panel is solid.
i will update with pictures of it fitted and what i did to fit it. sorry phone died. also have some POR 15 on the way, Ive been wanting to try it out for a while. _________________ 72 super beetle resto
Posted: Sun Nov 16, 2014 6:10 pm Post subject: |
Got the floor pans done today !
A few patches and really bad paint stains on my hands but got her done _________________ 72 super beetle resto
WD-40 Samba Member
Posted: Sun Nov 16, 2014 6:18 pm Post subject: Re: patch pan under battery |
RedHeadedJosh wrote: |
also have some POR 15 on the way, Ive been wanting to try it out for a while. |
A few patches and really bad paint stains on my hands but got her done |
Been there, done that! _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
Posted: Sat Dec 13, 2014 9:11 pm Post subject: |
Been sanding and fiberglassing the holes. Hopefully making a dent in my work. Hope to get to paint soon!!! Can't stand not driving her. Kinda just making my own steps as I go along and body work sucks.
The roof is sanded and painted and working on the driver door dent. _________________ 72 super beetle resto
