superblue72 Samba Member
Posted: Mon Oct 20, 2014 6:50 pm Post subject: crank moves 180 degrees and stops |
I have and engine a friend gave me years ago number B5 005 403. Out of wanting a new project I decided to tinker with it. Went to see it it was free spining and it would turn 180 degrees and lock up. I removed the rockers from the heads and the rods hoping that would free it, up no dice. Also I have the distributer removed. Planing on pulling the heads next. Any thoughts as to what could be causing this. Any feedback is appreciated. _________________ Lets go Ocho! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Posted: Mon Oct 20, 2014 6:55 pm Post subject: |
Loosen up the flywheel before proceeding to take the engine apart the rest of the way. _________________ In Stereo, Where Available! |
RedHeadedJosh Samba Member
Joined: June 04, 2011 Posts: 184 Location: Daphne, AL
Posted: Mon Oct 20, 2014 6:59 pm Post subject: |
shot in the dark but something may be on top of one of the pistons or bad crank. _________________ 72 super beetle resto
71 westy Resto ( http://www.thesamba.com/vw/forum/viewtopic.php?t=477613 )
Don't tell me what I can and can't do! |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Oct 20, 2014 7:14 pm Post subject: |
If it's sat long enough it could be a lifter stuck in its bore. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Posted: Tue Oct 21, 2014 6:45 am Post subject: |
I'm hoping there is just something in the cylinder. Is therea way to unstick the lifter without splitting the case? _________________ Lets go Ocho! |
Posted: Tue Oct 21, 2014 6:53 am Post subject: |
If it is stuck, it is probably rusty. Rusty steel parts are not good for moving at high speed, due to added friction and heat produced can quickly eat up parts. Best to not cut corners and just take it all apart.... _________________ In Stereo, Where Available! |
Posted: Tue Oct 21, 2014 7:11 am Post subject: |
Yeah your right on that. I did keep oil in the case just to try to keep things lubed just in case I did ever want to do anything with it should the lifter still be stuck sitting in oil? I know dumb question just covering my basis. _________________ Lets go Ocho! |
Posted: Tue Oct 21, 2014 7:17 am Post subject: |
Sump oil level is lower than the lifters. So unless you filled the case completely.....
Bought a 1963 SC that had been parked shortly after engine rebuild eight years before. Parked due to rocker arm stud pulled out. Changed oil and got 50 miles down range when the rusty crankshaft ate up the main bearings.... _________________ In Stereo, Where Available! |
Posted: Tue Oct 21, 2014 7:38 am Post subject: |
Point made thanks for the Iinput _________________ Lets go Ocho! |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8687 Location: Sunset, Louisiana
Posted: Tue Oct 21, 2014 8:45 am Post subject: |
Likely a rusted cylinder. But, don't go rotating that engine too much with the distributor removed. You could push the distributor drive up and jam it , which could then damage the brass gear inside the engine. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Tue Oct 21, 2014 12:59 pm Post subject: |
Oh hell,Im all in...broken rod...Vw's requirement for a 'core' engine was that it had to turn one revolution... |
Posted: Tue Oct 21, 2014 5:46 pm Post subject: |
After getting the heads off and cleaning out the rusty debris in cylinder #3 it now turns completely over with no prob.I posted some pics in the my gallery couldn't get them to load on forum.I think I have a bent exhaust valve which is why there was crud in the cylinder.but see what you think _________________ Lets go Ocho! |
cseay1 Samba Member
Joined: March 22, 2012 Posts: 1341 Location: Elkwood VA
Posted: Wed Oct 22, 2014 5:51 am Post subject: |
Hey thanks!! _________________ Lets go Ocho! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Wed Oct 22, 2014 7:54 am Post subject: |
OH that poor thing- What are your plans?? _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Wed Oct 22, 2014 10:17 am Post subject: |
I don't really have much of a plan just kinda playing around _________________ Lets go Ocho! |
cseay1 Samba Member
Posted: Wed Oct 22, 2014 4:18 pm Post subject: |
Ha ha well said I might just play around with redoing the valve and cleaning these heads never actually done that.What is a goo solvent to use to clean this or proper way , I ask to learn from others experince _________________ Lets go Ocho! |
Posted: Thu Oct 23, 2014 2:07 pm Post subject: |
With no history and the corrosion in the one head chamber, would just tear it down the rest of the way and rebuild it for that rainy day.... _________________ In Stereo, Where Available! |
