Wheel adapters 4 lug to wide 5?
earthquake
earthquake is offline
PostPosted: Mon Oct 20, 2014 10:50 pm    Post subject: Wheel adapters 4 lug to wide 5? Reply with quote
OK
One of the last things I did on my last job running the waterjet machine was to make a set of wheel adapter to go from 4 lug to wide 5, I cut them out of 1/2" high grade aluminum, do you think this will stand up to some mild off road [no more then 1 foot of air] ...
I will use studs in the drums and rotors and large 1" hex lug nuts and studs in the adapter plate for the wheel. I know I can get rotors and drums in wide five but I cant afford them right now and I already have the adapters cut, I made 5, one will be a balance adapter.
Do you think they will be strong enough? Thanks for any help.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
Brian
Brian is offline
PostPosted: Tue Oct 21, 2014 1:24 am    Post subject: Reply with quote
They look pretty sturdy. But I would put a seat in for the lugs, and some press in studs on the wide 5.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Dale M.
Dale M. is offline
PostPosted: Tue Oct 21, 2014 6:22 am    Post subject: Reply with quote
Yes...
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Tue Oct 21, 2014 1:15 pm    Post subject: Reply with quote
The Micro Stub setup used for racing uses a aluminum adapter like yours to go from the small 5 lug pattern to the wide 5.
One of the Class 5 Baja Bug I use to prep flipped over several times at about 80mph. When assessing the damage after, the micro stub hub had bent in the bearing area and the adapter was still straight and usable.
I think it will hold up well unless you are using an extreme off set wheel.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
takotruckin
SUPER Baja
takotruckin is offline
PostPosted: Tue Oct 21, 2014 7:59 pm    Post subject: Reply with quote
That thing looks beef. It should be fine.
Member of the baja's that don't run club, for now!!
Multi69s
Multi69s is offline
PostPosted: Sun Oct 26, 2014 12:56 am    Post subject: Reply with quote
What grade of aluminum did you use?
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
earthquake
PostPosted: Mon Oct 27, 2014 3:03 am    Post subject: Reply with quote
Multi69s
As far as I can remember its 6061 T6, I don't think we ever used any thing else in 1/2" plate. I cut them out over 2 years ago and my memory not as good as it used to be, I will look the rest of them over and see if there's any printing on one of them.
Casey
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
HILLAHOLIC
HILLAHOLIC is offline
PostPosted: Mon Oct 27, 2014 9:32 pm    Post subject: Reply with quote
They'll be fine for extreme use. That's the same material I'm running on mine. It's been rolled hard 17 different times and they've held up.
[/youtube][/url]
