New hoses.... No clamps
Miaghia
Miaghia is offline
PostPosted: Tue Oct 21, 2014 4:18 pm    Post subject: New hoses.... No clamps Reply with quote
No clamps required according to a 65 year old 45 year Vw experience expert. He says correct size cloth wrapped hoses require no clamps. He said put them on and then try to get them off the next day. He is correct... Cannot even get them off to put a clamp on!!!
-Zodiac-
-Zodiac- is offline
PostPosted: Tue Oct 21, 2014 4:21 pm    Post subject: Reply with quote
Yepp no clamps,and where did you get your hoses?
1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives.
Miaghia
Miaghia is offline
PostPosted: Tue Oct 21, 2014 4:36 pm    Post subject: hoses Reply with quote
Bell metric for the large auto stick grunt valve hoses. Ebay for the green cloth. The old german dude (no clamps) for the 3.5 and 5mm vacuum and fuel
anthracitedub
anthracitedub is offline
PostPosted: Tue Oct 21, 2014 5:28 pm    Post subject: Reply with quote
I've found that they do stay on quite well. I do recommend checking the condition of the hoses often.
-Zodiac-
-Zodiac- is offline
PostPosted: Tue Oct 21, 2014 5:31 pm    Post subject: Reply with quote
the braid works like Chinese finger traps, I'm missing afew and need to order some
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Oct 21, 2014 6:30 pm    Post subject: Reply with quote
VW in the 1970s put out a bulletin that told VW mechanics to install clamps on hose between fuel pump and carb. That part of the fuel line is under pressure and will loosen the chinese finger cuff action of the fuel line.
In Stereo, Where Available!
akear
akear is offline
PostPosted: Tue Oct 21, 2014 7:11 pm    Post subject: Reply with quote
I run braided with FI type clamps. Why tempt fate?
NOVA Airhead
NOVA Airhead is offline
PostPosted: Wed Oct 22, 2014 6:12 am    Post subject: Reply with quote
I use clamps on all my fuel line connections. I do not use the worm drive clamps but these:
http://www.karmannghia.com/viewDetail.asp?strMasterCat=&idproduct=8410
They are cheap protection.
Ghia Owner Emeritus
cseay1
cseay1 is offline
PostPosted: Wed Oct 22, 2014 8:21 am    Post subject: Reply with quote
I would rather be overkill and do this rather than watch my car burn to the ground on the side of the road
Chris
1968 Karmann Ghia coupe - build log here: Chris' 68 Ghia Build Log - From the Woods back to the Street
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Oct 22, 2014 8:25 am    Post subject: Reply with quote
I agree, you should put clamps on the fuel line. And if you can't get the hoses off than you can unscrew the clamp and then put it on the hose to tighten it.
And speaking of side of the road - you can use a dime to loosen and tighten the clamps, some people don't know this Idea
thruhiker74
thruhiker74 is offline
PostPosted: Wed Oct 22, 2014 9:49 am    Post subject: Reply with quote
Funny. I noticed on my recently purchased '62 the lack of clamps on the braided cloth-sleeved lines for the fuel just this past weekend. Couldn't get the lines to move at all, but still plan to get clamps and tighten them down.
Miaghia
Miaghia is offline
PostPosted: Wed Oct 22, 2014 10:47 am    Post subject: safety wire... Reply with quote
So, the clamp holds the hose to the fitting... and the safety wire holds the fitting into the carb. I get that.
I have also seen where folks safety wire the hose clamps where the hose is clamped to a metal line... WTF? Have we lost all confidence in clamps holding hoses onto pipes?
And, to take it a step farther, I have seen safety wire applied under a nut/bolt going the wrong direction! So, paranoid that the clamp won't hold the hose on but add safety wire in an orientation such that it loosens the hose clamp!
I plan to follow advice here and add (2) hose clamps only on the line from pump to carb that is carrying 3 PSI. And, maybe (1) safety wire to hold that brass fitting into the carb.
Good discussion guys
John Moxon Premium Member
John Moxon is offline
PostPosted: Wed Oct 22, 2014 10:57 am    Post subject: Reply with quote
Yep that's how I secured my carb fuel line on my Beetle.
John.
mlhsquared
mlhsquared is offline
PostPosted: Wed Oct 22, 2014 11:00 am    Post subject: Reply with quote
Here's what I did instead of the safety wire. I very carefully drilled and tapped the fuel inlet and installed a barbed fitting. There are good instructions on here somewhere. If I find them, I'll post the link.
I also installed hose clamps on either end of the fuel line.
Mike
'67 Ghia Coupe
NOVA Airhead
PostPosted: Wed Oct 22, 2014 11:01 am    Post subject: Reply with quote
You can also tap where the pipe goes into the carb and use a threaded fitting with barbed end. This was done on my last carb rebuild.
That eliminates the need for the wire on the clamp.
Ghia Owner Emeritus
mlhsquared
PostPosted: Wed Oct 22, 2014 11:02 am    Post subject: Reply with quote
Beat ya to it, Mike. Laughing
It's worth adding that Tim at http://volkzbitz.com/ will do this to any carb that he works on or sells for a small additional fee.
Mike
'67 Ghia Coupe
c21darrel
c21darrel is offline
PostPosted: Wed Oct 22, 2014 1:59 pm    Post subject: Reply with quote
This is a reasonable thought. If you are thinking of the main fuel line coming into the engine area from above the trans. The ones to wire are the fuel line into the inlet on the carb and fuel pump. These are known to pop out and then you have a fuel geyser all over an inclosed space with a big spark maker. Thats why Nova and mlh2 have brilliantly tapped and threaded in the pipe.
GhiaBuild
1967 DC build
danny gabbard
danny gabbard is offline
PostPosted: Wed Oct 22, 2014 5:07 pm    Post subject: Reply with quote
I started to safety wire also ! I had a stock brass tube come out one time , Lucky my 67 did not catch fire.
Shipping is NOT included in any of my products or parts. Just want to say thanks from GAB-FAB for any purchase!!
retrowagen
retrowagen is offline
PostPosted: Wed Oct 22, 2014 7:44 pm    Post subject: Reply with quote
Sometimes, the brass inlet tube pops out of the non-German Solexes... Clamps or no clamps! Definitely check yours out often, before it's too late
David Ruby
President, Karmann-Ghia World Club
danny gabbard
PostPosted: Wed Oct 22, 2014 8:00 pm    Post subject: Reply with quote
Whats nice about safety wire is it keeps the brass tube in carb.
