keiths 69 Samba Member
Posted: Tue Oct 21, 2014 9:48 pm Post subject: 009 timing |
Sorry for another distributor question but I cant find my problem in other posts. Ive got a 71 maybe 72 case believed to be a stock 1600 in my 69 bug with dual kadron 40's on it with a 009 dist with points. Ive been trying to get ride of a under normal acceleration hesitation for a while. If I run it hard it seems to be fine. Any way today i pulled the plugs and they are burning fine. Points are spot on, valves are good so on and so on. Ive done the reading on the 009 and today i got the timing light out and checked it. it was at 6/7 btdc at idle and about 22 atdc at 3000 rpm. I fallowed Rob and Dave's advice and set it to 32 atdc at 3000 rmp. runs AWESOME hesitation is gone no pinging, great. My concern is it idles at 8 atdc. Everything i read says it falls to a btdc range between 5 or 10 sometimes 16. Mine does not. I get that the 3000 rmp setting is the important one but it still doesnt seem right that it idles atdc. Is it a issue? Id hate to burn it up. Thanks ahead for any help |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Posted: Tue Oct 21, 2014 9:54 pm Post subject: |
yes to the right of tdc sorry |
Posted: Tue Oct 21, 2014 9:56 pm Post subject: |
at idle and at 3000 rpm are both on the right side of tdc |
Posted: Tue Oct 21, 2014 10:11 pm Post subject: |
thanks bro. It just dawned on me that i was bass akwards with my thinking on the timing marks. thanks for the smack on the back of the head |
Frodge Samba Member
Posted: Wed Sep 14, 2016 4:34 pm Post subject: Re: 009 timing |
Adjusted timing at full advance and it falls at 28 btdc and 12 idle. OK? |
Frodge Samba Member
Posted: Wed Sep 14, 2016 4:41 pm Post subject: Re: 009 timing |
Thanks. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Wed Sep 14, 2016 6:25 pm Post subject: Re: 009 timing |
Frodge wrote: |
28-12=16*.
A 009 should have 22*.
Chinese crap. _________________ Glenn
Member #1009
#BlueSquare |
Frodge Samba Member
Posted: Wed Sep 14, 2016 6:42 pm Post subject: Re: 009 timing |
Hmm.. What do I do now? It seems to run fine. |
Glenn Mr. 010
Posted: Wed Sep 14, 2016 6:47 pm Post subject: Re: 009 timing |
Then drive it..
28* total will not hurt the engine. But your performance might suffer. _________________ Glenn
Member #1009
#BlueSquare |
Frodge Samba Member
Posted: Wed Sep 14, 2016 6:58 pm Post subject: Re: 009 timing |
Do you still sell a svda for solex 30 Pict 3? |
Glenn Mr. 010
Posted: Wed Sep 14, 2016 7:02 pm Post subject: Re: 009 timing |
I do not.
You want a 205T. _________________ Glenn
Member #1009
#BlueSquare |
Frodge Samba Member
Posted: Wed Sep 14, 2016 7:12 pm Post subject: Re: 009 timing |
Thanks. |
mark tucker Samba Member
Posted: Thu Sep 15, 2016 9:38 am Post subject: Re: 009 timing |
runs great.. dont screw with it. |
Glenn Mr. 010
Posted: Thu Sep 15, 2016 9:48 am Post subject: Re: 009 timing |
mark tucker wrote: |
runs great |
Less filling.
Actually it can run better. _________________ Glenn
Member #1009
#BlueSquare |
Frodge Samba Member
Posted: Thu Sep 15, 2016 10:02 am Post subject: Re: 009 timing |
Where can I get the correct distributor? |
