vw60bug Samba Member
Joined: August 11, 2003 Posts: 215 Location: Newport News Va
Posted: Tue Oct 21, 2014 11:42 pm Post subject: Stuck fuel cap |
I have a 57 oval. I went to remove the gas cap to check and see how much fuel I have, and the gas cap will not budge! I cannot get it to spin off the tank. Anyone experience this and have a way to remove cap without destroying it? Any help would be much appreciated. |
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Wed Oct 22, 2014 12:17 am Post subject: |
PB Blaster to loosen the rust. Or even better equal parts diesel and acetone, according to tests right here on the Samba it works better than PB Blaster.
That and a great big plumbers wrench. Although there is much cringing as I suggest that wrench, I would sure hate to see you bugger up the tank. |
Joe Bence Samba Member
Joined: March 14, 2004 Posts: 501 Location: San Diego, CA
Posted: Wed Oct 22, 2014 12:36 am Post subject: |
strap wrench |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Oct 22, 2014 12:52 pm Post subject: |
Why is it stuck? Is it rusted on? Thats doubtful.
It may simply be a case that the tab on the bottom of the cap got bent up and now won't release from it's catch.
Make sure you are applying pressure down on the cap when you try turning it.
And just to make sure, you are turning in the right direction??????
Is there any movement in the cap at all? _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Wed Oct 22, 2014 5:47 pm Post subject: |
I got it!! The tab was stuck, I pushed down and pulled to one sideand it came off. Thanks for all the input! |
55VOLKY Samba Member
Joined: October 23, 2012 Posts: 48 Location: colorado springs
Posted: Sat Oct 25, 2014 8:47 pm Post subject: |
One thing to consider is a cork gasket, I had a rubber gasket and it was a pain to take the cap off so I was using a strap and it would come off easier but now with a cork gasket It comes off very easy and don't even need the stap. |
