thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Wed Oct 22, 2014 6:51 am Post subject: Vintage Speed Sump Plate. How to Install Longer Studs? |
I bought a Vintage Speed sump plate a while back for my engine.
I tried to install it, but it seems to require longer studs.
Is there a way to remove and replace the stud that holds the pick up tube in place without splitting the case? There's a nut on top that I can't reach.
The other 5 studs should be easy to remove. _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Oct 22, 2014 7:25 am Post subject: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=482046
you need to get creative and make a tool. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
RHough Samba Member
Posted: Wed Oct 22, 2014 7:36 am Post subject: |
One has to ask ...
What could possibly be enough better about a sump plate that would make you consider changing the studs to use it? |
Posted: Wed Oct 22, 2014 7:41 am Post subject: |
[quote="RHough"]One has to ask ...
What could possibly be enough better about a sump plate that would make you consider changing the studs to use it?[/quote
It's machined perfectly flat on the gasket surface and should be less prone to leaking. _________________ 1957 Vintage Baja Bug.
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Wed Oct 22, 2014 9:09 am Post subject: |
It doesn't look machined, it looks like the holes were stamped, and someone took a sander to knock off the high spots... _________________ foam cowboy hats aren't good helmets. |
Posted: Wed Oct 22, 2014 10:27 am Post subject: |
tripicana wrote: |
It doesn't look machined, it looks like the holes were stamped, and someone took a sander to knock off the high spots... |
Your looking at the bottom. The other side has been machined flat. _________________ 1957 Vintage Baja Bug.
theDrew Samba Member
Posted: Wed Oct 22, 2014 6:41 pm Post subject: |
Yikes! I'll just stick with the stock sump plate for now. Too much work to replace that stud. _________________ 1957 Vintage Baja Bug.
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Thu Oct 23, 2014 9:57 am Post subject: |
Buy a cheap 10mm wrench that you can bend using a torch.
I did that decades ago and have used it many times over the years. |
