ZAIRKUHL Samba Member
Joined: September 12, 2004 Posts: 33 Location: HUDSON VALLEY, NY
Posted: Wed Oct 22, 2014 10:11 am Post subject: Magna Spark II distributor. |
Just recently purchased a new Magna Spark distributor from CB Preformance. Included in the box is the "Advance Kit"; a small zip lock bag containing additional springs, bushings, the O-ring for the end of the distributor shaft and three ultra thin washers or, perhaps, spacers. Can anyone inform me as to the purpose of these three washes/spacers? Thanks. |
theDrew Samba Member
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Wed Oct 22, 2014 11:11 am Post subject: |
theDrew wrote: |
Call them. |
1-800-274-8337 _________________ Glenn
Member #1009
#BlueSquare |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Wed Oct 22, 2014 11:21 am Post subject: |
The kit comes with very detailed instructions.
The stronger (they word it as heavier) springs reduce the rate of advance.
The larger spacers limit the total advance.
I have the medium rate in mine, and set the advance limits to provide 10 degrees idle and 30 total for my low compression (9.5:1) 2275 engine.
You can't just go off their chart for total advance bushings/spacers vs actual advance. They don't jive. It takes guess and check methods and a good timing light/degree pulley. |
Posted: Wed Oct 22, 2014 1:55 pm Post subject: |
Thanks for the replies. I understand how to set up a desired advance with the provided springs and bushing. My apologies if I didn't make myself clear. I've included an image of the contents of the "Advance kit" I received with the distributor.
My question is "What are the three thin washer/spacers in the lower right of the image for?". Thanks again. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Wed Oct 22, 2014 2:10 pm Post subject: |
Adjusting distributor drive end play (distributor engagement depth) _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Thu Oct 23, 2014 4:11 am Post subject: |
Again, thanks to all for the replies. Any suggestions on the starting point for setting the end play? Thank you. |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Thu Oct 23, 2014 6:25 pm Post subject: |
ZAIRKUHL wrote: |
I have read .010" on here but I cant find the post. Its strange that there is no spec for that in the Bentley manual. _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
