earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Wed Oct 22, 2014 11:01 am Post subject: Rods? |
OK
Are the rods in a 1500 pretty much the same as 1600 rods? I am putting together a 1915 but its pretty much going to have stock heads for now.
I have a set of CB HD Untech rods but I don't wan't to use them in this motor, I have two complete 1500's [there H code motors] that have never been broke down, would a set of rods from one of these be ok? I wan't to save the CB's for a stroker motor down the road.
The motor I am going build will be...
AS code DR case
stock DP heads/ stock valve train & new springs
Engle 110 cam
DPR 69mm CW crank
AA P&C's
40mm Weber IDF's
and whatever other parts I need.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Air Cooleds Only Samba Member
Joined: October 18, 2009 Posts: 157 Location: Prescott, AZ
Posted: Wed Oct 22, 2014 11:56 am Post subject: |
1500 & 1600 share the same rod. _________________ Air Cooleds Only |
Danwvw Samba Member
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Wed Oct 22, 2014 4:00 pm Post subject: |
The 1500 rods will work fine. Just check them out as you would any used part. |
mark tucker Samba Member
Posted: Fri Oct 24, 2014 9:19 am Post subject: |
if there good to go then.....it's up to you. if they need reworking.....the cb will be better.with this stated ...Ive never used a vw rod. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
