crvc Samba Member
Posted: Wed Oct 22, 2014 11:18 am Post subject: Turn signal question |
I have a '67 with two year old wiring. If a bulb burns out the dash flasher still works but at triple speed. It's doing that now but all the bulbs work. The right rear turn signal light is much dimmer than the left. I don't know anything about electricity. I do know most VW electrical problems have to do with grounding.
Any suggestions?
TIA
crvc |
carcrazed Samba Member
Posted: Wed Oct 22, 2014 12:24 pm Post subject: |
check first to see if your bulb is in properly. The next thing I would look at is a bad ground at the light. Unscrew your ground wire and clean it up. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Oct 22, 2014 3:35 pm Post subject: |
If your taillights are still grounded through the housings (stock), then loosen the nuts (8mm I think), scrub the bolt-down areas with a brass brush- then retighten all 4. It will often restore matched brightness in the rears. The fronts can benefit the same way- but are less-so bombarded with road crud when driving.
A bad ground in one bulb makes the turn signal circuit "see" a decrease in resistance- thus the well-grounded bulb flashes double time because the flasher thinks the one good bulb is all alone in the circuit. You may also see a faint glow in the taillight bulbs due to the same phenomenon- the circuit seeks a ground via feedback through the rest of the taillight housing. You may have to pull the rear lenses and perform the same ground maintenance on the two anchor screws at the bottom of the reflectors- but they will come back. _________________
EverettB wrote: |
FU#5 |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
DrKeck Samba Member
Posted: Tue Oct 28, 2014 7:36 pm Post subject: |
I think your bulb is upside down, if one is brighter than just take of the tai light covers and see if they are in properly. _________________ 1966 Beetle
1600cc 50bhp
Daily Driver |
crvc Samba Member
Posted: Thu Oct 30, 2014 9:37 am Post subject: |
I smeared everything with dielectric paste. That didn't do anything. Now the right rear bulb doesn't work while the dash flasher stays on but without blinking. When I get the time I'll add a ground wire from the bulb casing to the underside of the fender.
Thanks for the help,
crvc |
