dixoncj Samba Member
Joined: June 17, 2004 Posts: 1083 Location: Charleston, SC
Posted: Fri Oct 24, 2014 10:32 am Post subject: |
Terry Kay wrote: |
Not only a good idea, It would be prudent to load up the grocery bag with everything you could possibly think of to update, or change under there.
The full meal deal.
This operation isn't going to bust up your knuckles, but it'll suck up hours like crazy.
I denote it as an unsavory, I despise it kinda job that is much better done only once if you can get away with that.
Phooey. |
TK, I hereby nominate you to create that list, and then I hereby nominate the mods to afterwards make that list a sticky.
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Fri Oct 24, 2014 1:38 pm Post subject: |
huh, mention of the 1.9 water pump job brought back a memory....and thanks for that.
I did the 1.9 w.p. in a downtown parking space in Seattle, feeding quarters into the meter as folks wandered around me....
I remember making some uh... modifications, to get through the job quickly, worried the cops would give me a "mechanic in the street" sort of ticket.
That was almost 10 years ago I think.
Hey, we had a similar thread going on with this same theme back then.
http://www.thesamba.com/vw/forum/viewtopic.php?t=236401&highlight=water+pump _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
nacradriver Samba Member
Joined: January 15, 2009 Posts: 760 Location: Ventura, CA
Posted: Fri Oct 24, 2014 2:41 pm Post subject: |
I'm reading here on what a bear the water pump replacement for the 1.9, and what am I not getting... To me, on my 1985 it was a pretty straight forward simple job... Yes, couple of cuts on the knuckles, but at the most I remember it was a two hour job..... I believe I replaced three of them.
What I did do is buy a few sockets, bent some re-bar for handles for the hard to reach spots, welded them together and made a special tool. Should have saved those..... but they got towed away with the van.... oh well...
I will agree the spring clamps were a _______ to deal with.
On the other hand, this van didn't have AC or Power steering either... maybe that is what made it simple. _________________ Güdrun -1989 Westfalia - 2013 - 2018
Petra - 1985 Vanagon - 1985 to 1991
Zisa - 1974 VW Van "Bus" - 1974 to 1985
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Fri Oct 24, 2014 2:43 pm Post subject: |
Wear gloves. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
Timwhy Samba Member
Posted: Fri Oct 24, 2014 3:24 pm Post subject: |
For me it wasn't a replacement as much as it was an installation. I bought a rear tire carrier from
RMW and everything in the kit was staright forward. Great directions and I have to say I am super
pleased with how everything turned out.
When I was installing it, I had to stick my arm down the rear vent collumn to line up the backing plate
for the carrier. There are several sharp screws inside that tunnel and I caught everyone one of them on
the way down and on the way up! Bleeding for my Westy! lol
_________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Fri Oct 24, 2014 6:54 pm Post subject: |
Andrew A. Libby wrote: |
I think it is all a matter of attitude (whether or not you are currently enjoying yourself) and expectation (whether or not you think it should be easier than it is).
[insanity]If you are currently not enjoying yourself and you think the job is harder than it should be then it is a PITA.[/insanity]
If you are enjoying yourself and see the job as a task that has to be performed that requires a reasonable amount of time and effort then every job is fun.
The often misunderstood fact is that everyone has control over their attitude and their expectations. If it is a PITA, you make it so in your own mind. If it is fun, you make it so in your own mind.
As I mentioned in the opposite thread, one of my favorite tools for adjusting both my attitude and expectations when working on a vehicle is entertainment. I place an audiobook on my ipod and press play. From that point on, the job could take 10 times as long as it 'should' and I don't really care. Often I get done with the audiobook and find it amazing how much my 'other self' accomplished while I was enjoying a good book. |
Word! |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Fri Oct 24, 2014 7:04 pm Post subject: |
The Elder Hannover Gods are pleased with your blood sacrifice, the job is an assured success.
If you bleed, you succeed. Works every time, 80% of the time. _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
rubbachicken Samba Member
Posted: Fri Oct 24, 2014 7:49 pm Post subject: |
one of the should be simplest of job, i alway struggle with is getting the fuse box cover off of a late vanagon.
they go back on easy enough, i always need to fight to get them off _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
syncromike Samba Member
Joined: November 14, 2011 Posts: 660 Location: Boise, ID
Posted: Fri Oct 24, 2014 10:22 pm Post subject: |
My vote goes for the Syncro w/locker starter, especially when replacing a stock starter with a gear reduction starter. I'd rather remove the dashboard and replace everything in there before touching my starter again.
I had to remove the locker, drop the right side engine mounts, remove throttle body, and God knows what else before I could get that new starter in there. _________________ _____________________
'91 Syncro w/ Country Homes PopTop |
Posted: Sat Oct 25, 2014 1:01 am Post subject: |
the only one if have ever swapped out , didn't seem as much of a PITA as you are describing.
syncromike wrote: |
I had to remove the locker, drop the right side engine mounts, remove throttle body, and God knows what else before I could get that new starter in there. |
meet 'burni'
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sat Oct 25, 2014 8:06 am Post subject: |
dixoncj wrote: |
Terry Kay wrote: |
The full meal deal.
Phooey. |
TK, I hereby nominate you to create that list, and then I hereby nominate the mods to afterwards make that list a sticky. |
That thread already exists:
http://www.thesamba.com/vw/forum/viewtopic.php?t=265457&sid=c3ea378640f8d0f361d2ed849d503c3a _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
devesvws Samba Member
Joined: January 05, 2004 Posts: 1540 Location: madison va
plummerdesign Samba Member
Posted: Sat Oct 25, 2014 11:22 am Post subject: |
Gotta go with door number one…water pump (1.9 in my case).
Even with the engine out and on the bench this item takes too much thought. In the driveway it takes hours. The biggest hurdle comes if the t-stat housing has bolts either stuck or seized. These GEMS are made of un-obtainium and so require labor intensive work to restore. Torches, presses, chemicals and hammers OH MY! To top off this joyful procedure is the likelihood of purchasing a weep-hole leaker that will show it’s true self in about a years’ time.
Over all - my experience is that these engines are easier to live with and work on when compared to current vehicles. Consider last year when I spent DAYS removing and replacing the water pump in my wife’s ’03 Intrepid. Even R+R of the water pump on my daughters’ Neon was crazy nuts wickedness.
Cheers,
Jeffery _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
VWagabond Samba Member
Joined: March 19, 2011 Posts: 272 Location: Charlotte, NC
Posted: Sun Oct 26, 2014 6:39 am Post subject: |
Terry Kay wrote: |
I'd have to say, ( and not because it's a knuckle buster but a big PITA job) anything that's forward of the two front seats.
Need a new wiper motor?
Pull the dash.
Need to work on or replace the wiper trans gear?
Pull the dash.
Need a heater motor?
Pull the dash.
Need a heater core?
Pull the dash.
Need windshield washer hoses?
Pull the dash.
I know there's guys that claim to have done the job in 2 hours flat.
Maybe pull the dash and put it back in without doing anything under it--maybe.
I enjoy working on older vehicle's, and trucks that everything is right out in front of me.
Not a trip into Wonderland to just have the opportunity to be able to get to --lets say, the wiper motor--
Time consuming, and might as well make a weekend out of the job--do everything all at once, get done with it all --
Big Pain-- |
I think the lesson here is if you pull the dash for anything then go ahead and replace everything that can malfunction. As for the designers of the Vanagon, I thing the head engineer was an Irishman named Murphy. I know everytime there are repairs to be made on the KrauteKan, Murphy seems to show up to help. I also think he helped to write the Bentley. _________________ The Road Goes Ever On & On……...
VWagabond
87 Camper GL
87 Syncro GL |
madspaniard Samba Member
Posted: Sun Oct 26, 2014 8:14 am Post subject: |
rubbachicken wrote: |
they go back on easy enough, i always need to fight to get them off |
Good to hear I'm not the only one that struggles with this, I can never remember the proper way to remove this cover. Not really a PITA, just a bit frustrating. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Oct 26, 2014 8:23 am Post subject: |
x3
I just spent $25 to replace mine - now I'm afraid to open it... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1857 Location: anchor pt. alaska
Posted: Sun Oct 26, 2014 8:28 am Post subject: |
I dont know but i had a helluva time getting uca bolt out yeterday. |
