Horn grille directionals..How-To
grandpa pete
grandpa pete is offline
PostPosted: Wed Oct 22, 2014 3:20 pm    Post subject: Horn grille directionals..How-To Reply with quote
Ok students ; todays lesson will discuss putting directional lights behind the horn grilles
When I got my 66 used fenders the PO had welded up the directional holes in the top of the fenders
This is a modification..This is not original.....This is not for everyone
I will be using two $9 trailer lights
I used an extra nut on the post to space the light in the existing hole
I drilled 1/2 inch holes in the sides of the spare tire well . Fender still removeable .
Simple ; no brackets to build ; wired in to original harness
other side.......Bent the horn support to fit light
Dual element bulb gives me directional and parkinglight Cool
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
Benfish
Benfish is offline
PostPosted: Thu Oct 23, 2014 8:18 am    Post subject: Reply with quote
Cool mod GP. Looks good behind the horn grill.
1966 Sea Blue Sedan
eyetzr Premium Member
eyetzr is offline
PostPosted: Thu Oct 23, 2014 11:24 am    Post subject: Reply with quote
I think GP does all his shopping at the truck stops. Is the light you are using double sided or 1 sided? Doubles look cool at night, kind of cheap neon (flashback)
I think he meant "rare", as in "not well-done"
babysnakes
babysnakes is offline
PostPosted: Thu Oct 23, 2014 12:46 pm    Post subject: Reply with quote
There isn't anything you can't get from a truck stop, parts, food, clothes, a shower, women.......
eyetzr is offline
PostPosted: Thu Oct 23, 2014 1:05 pm    Post subject: Reply with quote
Women, really Shocked
grandpa pete
PostPosted: Thu Oct 23, 2014 3:13 pm    Post subject: Reply with quote
DEFINATELY !! Very Happy Very Happy
and NOT the type you take home to meet momma !!
We call them " lot lizzards " and there are even decals sold that say "NO LOT LIZZARDS " that you put on your truck so no one knocks on your truck at 2am to see if you want to " party "
Double sided light , red on the back glows under the car Smile
63 two fold rag
youngnstudly
youngnstudly is online now
PostPosted: Fri Oct 24, 2014 8:38 am    Post subject: Reply with quote
I like the lights you used for this project, GP. I did the same mod to my bug back in my teen years, but I only had amber trailer lights from the FLAPS to use as turn signals. I bent up brackets from 1/4" flat stock to mount the lights and "catch" one of the fender mounting bolts. Everything looked cool with the top of the fender now smoothed off.
However, when all was said and done, I quickly found out that I was getting cut-off by other drivers who apparently couldn't see my turn signal from the side of the car. All that work for nothing. Sad After that I put the turn signals inside the headlight bucket where the parking bulbs usually are and things improved a little. The entire headlight lens flashes brightly, but I don't think either modification would be considered "legal" by Mr. Policeman/woman if I were to get pulled over. At least I could probably pull the old, "My car is a European model that didn't come with turn signals on the tops of the fenders.....One year only thing for 1963!" Wink
The economy is in a state of disaster, we have NO time for common sense!
grandpa pete
PostPosted: Sun Oct 25, 2015 8:08 am    Post subject: Reply with quote
That's why I used a double sided light...the red glows under the fender and lights it up .
63 two fold rag
EMPIImp69
EMPIImp69 is offline
PostPosted: Thu Dec 24, 2015 6:49 am    Post subject: Re: Horn grille directionals..How-To Reply with quote
Thanks Grandpa for the write-up.
1963 Ragtop Bug
jerry7297
jerry7297 is offline
PostPosted: Mon Dec 28, 2015 11:26 am    Post subject: Re: Horn grille directionals..How-To Reply with quote
Very cool Idea. I may be doing this to my 60. Thank you sir.
itskyle
itskyle is offline
PostPosted: Mon Dec 28, 2015 4:06 pm    Post subject: Re: Horn grille directionals..How-To Reply with quote
I loved this idea. For those of you vintage purists, the 356 Porsche horn grills also had lights in them. Some of you WW buying, bone stock preferring crowd might lean towards that direction, but those parts are even more difficult to find than a 66 hazard switch or a pristine 1300 engine.
But, re-reading this post with GP's mention of the double sided light got me to thinking....
GP, what if you painted the inside of your front fenders with something shiny and reflective?
Would that make the whole area light up under the fender even better?
I know, I'm an idea guy, I have several. My wife typically doesn't like most of them Smile.
Kyle
69 or 72 Autostick Bug current
66 Bug (We both miss it)
74 SuperBeetle Auto Stick (I miss that car)
73 SquareBack, Straight Stick (Wife misses this one.)
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Tue Jan 08, 2019 4:09 pm    Post subject: Re: Horn grille directionals..How-To Reply with quote
Here is a 20 LED turn signal light that would solve your front turn signal issue.
It's visible in direct sunlight. The LED assembly is coated on both sides to seal it against rain water and road grime.
https://www.thesamba.com/vw/forum/viewtopic.php?t=708421&highlight=
Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
Digger89L
Digger89L is offline
PostPosted: Tue Jan 08, 2019 6:29 pm    Post subject: Reply with quote
You can add 'great scale model cars, even VW's' to that list. I don't drive a truck, but I try to gas up at truck stops from time to time just to check out their convenience store items. Many stops have a great selection of scale model cars and trucks. I recently picked up a WELLY No.22436 beetle, 1:24 scale for only $24 CDN. (similar online prices, but shipping doubles the cost). I tried to find out who their supplier was, but no luck.
"If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken."
rickshak
rickshak is offline
PostPosted: Mon Jul 01, 2019 6:14 pm    Post subject: Re: Horn grille directionals..How-To Reply with quote
Got the tractor trailer turn signal idea from you today. It worked out great. Thanks.
