CREATURE58 Samba Member
Joined: February 28, 2008 Posts: 494 Location: San Diego, Ca
Posted: Wed Oct 22, 2014 3:37 pm Post subject: Fuel Line Location Question.... |
So I noticed that my metal fuel line that goes from the tank to the engine is under the pan. My car sits really low and I noticed that the line has a few scrapes on it. Im guessing it has hit things before. Is it suppose to be on the outside of the pan? If not where? _________________ 1958 Bug (2180 Dual 48 IDA Webers and a Pro Street Flyer)
1997 Toyota Corolla |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Wed Oct 22, 2014 3:51 pm Post subject: |
No, it is supposed to be inside the frame tunnel (centre). It enters near the base of the gas tank where the frame head is exposed, and exits on the drivers side, left frame horn. _________________ 1958 Karmann Ghia owner |
Posted: Wed Oct 22, 2014 4:05 pm Post subject: |
Great thanks, I dont know why the previous owner did that
Will it be easy to put it in where it should go? _________________ 1958 Bug (2180 Dual 48 IDA Webers and a Pro Street Flyer)
anthonycanchola Samba Member
Joined: January 06, 2014 Posts: 122 Location: San Pedro, CA
Posted: Wed Oct 22, 2014 4:10 pm Post subject: |
Daum those PO _________________ 1981 Vanagon (traded)
1967 1776cc
2332 coming soon |
wcfvw69 Samba Purist
Posted: Wed Oct 22, 2014 4:50 pm Post subject: |
CREATURE58 wrote: |
Will it be easy to put it in where it should go? |
He probably did that due to the original leaking inside the tunnel. There's a link or several where people replaced the fuel line inside the tunnel w/great pictures illustrating the work. This is the way you should repair it, put it back in the correct location. _________________ Contact me at [email protected]
The Samba member since 2004.
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Wed Oct 22, 2014 6:52 pm Post subject: |
56Cabrio wrote: |
wcfvw69 wrote: |
CREATURE58 wrote: |
He probably did that due to the original leaking inside the tunnel. There's a link or several where people replaced the fuel line inside the tunnel w/great pictures illustrating the work. This is the way you should repair it, put it back in the correct location. |
here you go.
http://www.thesamba.com/vw/forum/viewtopic.php?t=380724 |
Thats a great DIY!!! Is there any other way to do this without cutting??? Not necessarily in the original place but not under the car as well hahaha _________________ 1958 Bug (2180 Dual 48 IDA Webers and a Pro Street Flyer)
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Wed Oct 22, 2014 7:16 pm Post subject: |
The Factory outlines an alternative method in the Service Manual...
http://www.socalautoparts.com/product_info.php/rob...rs-p-16767
...sorry, no pic's, but it basically has you run an external pipe through the bulkhead to the inside the car on the right side, then continue along the bottom of the tunnel, much like the brake pipe is but on the other side. It exits out the back near the Battery cable, then crosses over the yoke and along the left frame fork. Use grommets where it enters/exits the body, and clamp it down some way every foot or so.
Good thing about using this method is you can upsize the pipe to 5/16" or 3/8" to feed a thirsty motor _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
arizonabuckeye Samba Member
Posted: Thu Oct 23, 2014 1:16 pm Post subject: |
56Cabrio wrote: |
CREATURE58 wrote: |
56Cabrio wrote: |
wcfvw69 wrote: |
CREATURE58 wrote: |
here you go.
Thats a great DIY!!! Is there any other way to do this without cutting??? Not necessarily in the original place but not under the car as well hahaha |
Hotrodvw ran his under the car looks really nice. Check out his gallery pics.
http://www.thesamba.com/vw/forum/album_search.php?search_author=Hotrodvw |
Those SS hardlines are sweet but man... not an easy weekend type of a project. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Oct 23, 2014 3:15 pm Post subject: |
61SNRF wrote: |
The Factory outlines an alternative method in the Service Manual..) |
Found it for ya.....
1st65ghia wrote: |
Reading further in the Bentley there is a provision for an "Additional fuel line"
Seems like if the Bentley states this it must be an acceptable practice
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Thu Oct 23, 2014 6:19 pm Post subject: |
here it is a little bit less blurry
bluebus86 Banned
Posted: Thu Oct 23, 2014 7:19 pm Post subject: |
not as safe along the floor inside, if it leaks...... Tunnel is likely safest place for the metal gas pipe. keeps you from the gas, and protects it, under car protects you from gas, but may increase likely hood of leak from impact. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Fri Oct 24, 2014 5:07 am Post subject: |
glutamodo wrote: |
Well.... It is what it is when its somebody else's pic..
. _________________ aka Ken {o\!/o}
Posted: Fri Oct 24, 2014 6:34 am Post subject: |
Mine isn't exactly great either but that's because I intentionally made it low bandwidth... it was one of the first such images I ever put up, 10 years ago. |
Posted: Wed Jan 14, 2015 6:28 pm Post subject: |
So if I had somebody do the work how much should I be looking to pay? _________________ 1958 Bug (2180 Dual 48 IDA Webers and a Pro Street Flyer)
Posted: Fri Jan 16, 2015 1:51 pm Post subject: |
Bump _________________ 1958 Bug (2180 Dual 48 IDA Webers and a Pro Street Flyer)
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Fri Jan 16, 2015 2:35 pm Post subject: |
The alternative method via the service manual is about as simple as it gets. You can buy stainless steel tubing and run one solid piece to the rear. If this is a daily driver, I recommend this route. If you are doing a restoration, put it back in the tunnel |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Fri Jan 16, 2015 5:37 pm Post subject: |
I've replaced the brake line twice and both times took about half a day, working slow and easy to make sure nothing got X-threaded but that's not a concern with gas line. Go straight for high quality stainless as this is not something you want to do with cheap tubing unless you like to practice. The location lends itself to dampness if it's a driver or you have leaks in the car _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Mon Feb 02, 2015 11:29 am Post subject: |
So when replacing it should I put in a wider fuel line? Eventually I will be rebuilding my 2180 with electronic fuel pump and 48 webers. _________________ 1958 Bug (2180 Dual 48 IDA Webers and a Pro Street Flyer)
