kirbyland Samba Member
Posted: Wed Oct 22, 2014 8:36 pm Post subject: Rivets on sunroof header bow? |
What purpose did the rivets on the header bow serve? I don't see anything on mine that they held? |
EmpiGT Samba Member
Posted: Wed Oct 22, 2014 8:51 pm Post subject: |
The cover? are you talking about the ones about 3 inches apart all the way across? if so that keeps the cover material on. |
Posted: Thu Oct 23, 2014 6:04 am Post subject: |
yep- those ones. I've looked at my Bentley, and searched here- but don't see how the top is connected to the header bow by these rivets. I would think there wouldn't be enough material to grab well- and would tear to top? Are there washers, or something I'm missing that will hold the material better? Pics would be great! |
EmpiGT Samba Member
Posted: Thu Oct 23, 2014 9:09 pm Post subject: |
I'll see if I can find pics. you place the rivets in from the topside thru the metal bow, then thru the lower flap of the cover, then a washer, then swell them. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Fri Oct 24, 2014 9:13 am Post subject: |
I used tiny size #4 machine screws, washers, and locknuts. The protrusion doesn't interfere. |
Posted: Fri Oct 24, 2014 9:59 am Post subject: |
memory is foggy- is there a thin "pad" that goes on top of header? To help hide rivet heads? |
EmpiGT Samba Member
Posted: Fri Oct 24, 2014 12:49 pm Post subject: |
The holes should be stair stepped so the head of the rivet is sunk or flush with the bow, so no padding needed. just get the right size head to fit the recessed area. |
BarryL Samba Member
Posted: Fri Oct 24, 2014 7:02 pm Post subject: |
BarryL wrote: |
Countersunk for sure. I meant underneath where the nut will end up. Rivets are most original, of course.
Your ragtop front should have the header bow area sewn in front and on both sides to slip over the bow. Glue on the fat 1/2 moon weather seal then pull back and glue the flap EmpiGT mentioned before smashing the rivets. |
2Pack Samba Member
Joined: September 20, 2005 Posts: 807 Location: Virginia
Posted: Sat Oct 25, 2014 6:41 pm Post subject: |
Pop rivets are another option for this.
Original for reference:
_________________ Please buy my Treasure |
