shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
bluebus86 Banned
Posted: Thu Oct 23, 2014 8:13 am Post subject: |
a good print shop that makes label's might be able to scan your original and make label copies. Ideally you would want them to make a silk screen master, so you can have the paint screened on, rather than a label. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Oct 23, 2014 10:35 am Post subject: |
Contact member erokCom
He had some air filter decals reproduced...
http://1967beetle.com/oil-bath-air-cleaner-decal/
http://1967beetle.com/air-cleaners/
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Thu Oct 23, 2014 5:01 pm Post subject: |
Going back to your prior post on Air Cleaners (it might be best to keep it all under one topic, and the Mods usually prefer it that way too)...
shortride wrote: |
I have two air cleaners that have the same 113 129 613 E part numbers. The only differences is that one is made by MANN and the other is made by KNECHT. In my experience with part numbers in general, if a part is made by different manufacturers there usually is a difference in the part numbers or revision.
Which one is correct for a '66 Sedan? I'm guessing it could have either.
UPDATE: I think I found part of the answer but it doesn't explain why I have two dome style tops that have the same part number and "E" revision. Both lower parts are the same as well. http://www.thesamba.com/vw/forum/viewtopic.php?t=497250 |
...from what I know about VW part numbers, they only change the suffix if there is a difference in design or function. Tail lights and lens, turn signal switches, ignition switches, door handles etc all have at least two manufacturers/vendors, but if the part has the same exact application, the part number remains the same...
..when there is an update or revision, then they change the suffix up one alphabetic digit.
Also, keep in mind that the 1300 was sold in European '67's with the same exact air cleaner, so as far as the rest of the World it's not a one-year-only thing
As for your current question, my '66 has it's original '66 Knecht, which doesn't have that sticker or imprint you ask about. Perhaps it's a Mann thing, or that one is a replacement so it's marked bolder???
Anyway, the lettering on my example with original paint and finish (which looks like 90% of the US ones I've encountered) actually looks more like a tampo printing of red lettering over the black base coat rather than a sticker per say...
_________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Fri Oct 24, 2014 4:58 am Post subject: |
61SNRF wrote: |
shortride wrote: |
Thanks for the explanation. _________________ Pearl White 1966 Sedan
Retired US Army - 21 years 11B40, 173rd Airborne Brig. - Vietnam Combat Veteran |
AirCooledArtifacts Samba Member
Joined: March 30, 2007 Posts: 804 Location: Atlanta, GA
Posted: Fri Nov 14, 2014 10:21 am Post subject: |
Let me know if I can be any help. _________________ Eric Shoemaker, Owner
Air-Cooled Artifacts, LLC (formerly, Lane Russell)
“Reviving Classic Volkswagens”
aircooledartifacts.com
Follow our restoration work on Instagram.
Our vintage VW story — featured by Volkswagen of America, Inc, VW Trends & HotVWs |
Posted: Fri Nov 14, 2014 11:03 am Post subject: |
Yes. We stock both.
http://lanerussell.com/products/air-cleaner-decal
Rectangle decals fit VWs 1966 - 1971
Curved decals fit VWs 1953 - 1965 _________________ Eric Shoemaker, Owner
Posted: Fri Nov 14, 2014 11:04 am Post subject: |
You might also like our '67 decal pack.
http://lanerussell.com/products/decal-pack _________________ Eric Shoemaker, Owner
Posted: Fri Nov 14, 2014 11:52 am Post subject: |
shortride wrote: |
Thanks! I ear-marked both of them. |
Happy to help. _________________ Eric Shoemaker, Owner
