RidinRetro1973 Samba Member
TexasAircooledParts Samba Member
Joined: March 02, 2008 Posts: 60 Location: Katy, Texas
Posted: Thu Oct 23, 2014 6:13 pm Post subject: |
Share some details..
did this barely start happening? Has it ever worked?
Could be flasher or wiring.
Check the wiring to diagrams, ground connections, etc
If all checks out, replace the flasher _________________ www.texasaircooled.com
Ricardo [email protected] |
JKLundy Samba Member
Joined: July 16, 2014 Posts: 3 Location: Loveland Ohio
Posted: Thu Oct 23, 2014 9:14 pm Post subject: |
It kind of looks like the contact points in the relay are not breaking the circuit all the way. Relays can wear out over time. Every time the switch breaks contact there is a small amount of arcing which deposits a bit of carbon and roughens them, making it harder to break contact. If this symptom has progressively gotten worse I would look at the relay. If it came on suddenly I would look at the wiring. |
Posted: Fri Oct 24, 2014 8:31 am Post subject: |
JKLundy wrote: |
We had some heavy rainfall around here lately and the car sat outside for a couple days. At first the flashers would flash really fast, and then slow down to normal flashing rate. Now they just turn on and buzz like in the video. _________________ Instagram - VÄÄN Design Co.
My builds:
'68 AutoStick "Gawaine the Green Knight"
Modern Vanagon Westy Interior |
