Angus Dowrie Samba Member
Joined: March 07, 2005 Posts: 341 Location: Kangaroo Point, Australia
Posted: Fri Oct 28, 2016 2:56 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
SoCalJes wrote: |
Sorry for the off topic stupid question but why are the radio buttons LMMUU? |
Hi Jesse,
They stand for long, middle and ultra shortwave bands. European standard then. I won't be actually powering it up, just for show.
Angus _________________ 1963 Australian Delivery RHD Coupe
Build thread;
http://www.thesamba.com/vw/forum/viewtopic.php?t=610414 |
Posted: Fri Oct 28, 2016 3:05 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Rear bumper installed. Less obvious are the wheel studs. The CSP front disc kit comes with 14mm studs, so the standard vw lug nuts can't be used. I've had the rear drums changed to 14mm studs as well so that it is the same front and rear.
Sealant around the edges of the new mirrors...
And finally some dynamat to keep it a little quieter. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Fri Oct 28, 2016 3:42 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Very beautiful colour on your car, Angus. I think mine was that colour but much faded when I found it.
I'm going to wait to see what your radio looks like when it's fitted before I install mine for "show". _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Mon Oct 31, 2016 3:47 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Finally the converted genny has been finished! Had to buy a second genny as the first guy stuffed it up, but at least it will allow the engine to be put together and fired up! It's now an Australian Made Bosch , where it would have had a German one originally. It didn't have the original one when I bought it though, it was one from an oval era car.
Build thread;
Posted: Mon Oct 31, 2016 4:06 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
kiwighia68 wrote: |
I'm going to wait to see what your radio looks like when it's fitted before I install mine for "show". |
It's a nice colour, nice enough for me to deviate from the original pearl white!
Here is a couple of photos with the radio temporarily installed, before the knobs got painted but you get the picture.
Build thread;
Posted: Wed Nov 02, 2016 4:06 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Genny installed, engine together! Seems to be a fault with the ignition kit, no spark. At least I know it has oil pressure from cranking it over.
Build thread;
c21darrel Samba Member
Posted: Wed Nov 02, 2016 1:44 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
c21darrel wrote: |
That is a unique and beefy looking linkage you have there. What is it? |
Standard Riechert linkage kit. Riechert was a German tuning company from back in the day. I bought a partial kit which didn't have the linkage. It also had Mann oil bath air filters. I managed to find that Berndt Riechert is still around, selling any remaining stock I guess. He must be in his 80s now, I spoke to him a couple of times, and another sambanista (Udo) helped make it all happen as I think Australia was a step too far for Berndt to deal with!
He had two linkage styles, this one which just picks up the generator mounting set screws, or another which required welding a bracket to the fan housing. Both just use the standard accelerator cable. I preferred this one as like all other mods I have done it is bolt-on, completely reversible to stock if desired.
These air filters are the normal Riechert ones, I may still try using the Mann oil bath ones, although they are a little taller so may foul on the deck lid springs. Carbs are 28PCI. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
Last edited by Angus Dowrie on Tue Nov 15, 2016 12:32 pm; edited 1 time in total |
Posted: Thu Nov 03, 2016 3:08 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
c21darrel wrote: |
Thanks for the details. Very nice engine set up...I cant tell but looks like an 019 dist with a period brown cap, generator mounted regulator...those look like single throat carbs but not Kadrons. Very nice. |
Yes 019 distributor, Solex 28PCI carbs. Regulator is a standard bosch 12V unit. Has to be mounted 90 degrees to normal as the mounting tabs are different to the 6V ones. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
Posted: Thu Nov 03, 2016 3:15 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Angus Dowrie wrote: |
sputnick60 wrote: |
Mellow Yellow 74 wrote: |
Hi Angus, it is looking good. Can you show how you mounted the front number plate without drilling holes in the bumper? |
X2 I've still got cable ties on mine.
Nicholas |
The mount is one I bought through Rudiger at vintagecarparts.de ( from memory ), I can get his details if you are interested. They pick up the bumper bolts so pretty neat and tidy. I'll take some closer photos next week when I'm down. |
Was down today, some pretty ordinary photos of the mount. It doesn't pick up the bolts as I said above, actually just clamps onto the bottom trailing edge of the bumper bar. They were a bit of a impulse buy when I was putting a list together from Rudiger huber.
Build thread;
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Thu Nov 03, 2016 5:32 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Thanks Angus, I found some online - part number 111-707-999 for others interested _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Fri Nov 25, 2016 4:00 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Another significant milestone today, got the motor running!
Voltage drops, dodgy fuel pump etc conspired against us, but good to prove it ok. Was rebuilt by an old vw guru over 10 years ago, but has never fired up before! Warning lights both out so oil pressure and charging seem ok also.
The dual carbs need tuning, only had a rough tune so far. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
Posted: Wed Jan 04, 2017 12:28 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
Last bits going on. Front indicators complete, bonnet not bolted on yet until final wiring completed. Waiting for the gauge chrome trims to come back from metal polisher to complete the wiring.
Rear licence lenses are in, wiring to 3rd brake light run to the rear window vent. Not sure about the licence plate surround at the rear, it covers up a raised white edge trim on the plate so may remove it yet.
Windows and interior are waiting for all the chrome/anodised bits to come back from repairs/polishing/chroming. Frustratingly close to the end! _________________ 1963 Australian Delivery RHD Coupe
Build thread;
udo dreisoerner Samba Member
Joined: February 13, 2005 Posts: 1155 Location: Germany
Posted: Mon Jan 09, 2017 11:40 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
very very nice. wow _________________ Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
1525510 and 1525519 PLEASE OFFER ME ONLY THE CARS THAT I'M LOOKING FOR, THANKS!! |
Posted: Fri Jan 20, 2017 4:24 am Post subject: Re: Phoebe - After 10+ years the Resto begins! |
The windscreen rubber metal trim has finally come back, so Phoebe can head off to the upholsterer.
Needed those for the headlining to be installed. Shouldn't take too long, Kevin Ferguson has made the complete interior so it just needs fitting/installation. Not too much left to do now, hopefully be driving it soon! _________________ 1963 Australian Delivery RHD Coupe
Build thread;
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Fri Jan 20, 2017 4:57 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
sputnick60 wrote: |
Ah, the marathon comes to closing stages. It is certainly looking good 😊
Nicholas |
Thanks Nicholas, it certainly is a hard slog to finish these cars. My wife will be pleased I can take all the glass out from under our bed finally! _________________ 1963 Australian Delivery RHD Coupe
Build thread;
Posted: Fri Jan 20, 2017 9:14 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
sputnick60 wrote: |
Nicholas |
Thanks Nicholas, it certainly is a hard slog to finish these cars. My wife will be pleased I can take all the glass out from under our bed finally! |
My wife has got around to calling herself my "first wife", with my Ghia my "second wife". Or is it the other way around?
PS Good to see your car so close to the finish, Angus. As a one-time marathon runner, I can tell you that you get to the stage where you just want to get to the finish. And then, like magic, all the pain disappears and is forgotten. _________________ Festina lente - hasten slowly
Posted: Sat Jan 21, 2017 10:35 pm Post subject: Re: Phoebe - After 10+ years the Resto begins! |
kiwighia68 wrote: |
PS Good to see your car so close to the finish, Angus. As a one-time marathon runner, I can tell you that you get to the stage where you just want to get to the finish. And then, like magic, all the pain disappears and is forgotten. |
Hi Chris, never been a marathon runner, but have done some long bike rides (longest 300km in a day) so know that feeling! Hopefully the pain will disappear over the next few weeks. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
