DanPorges Samba Member
Joined: September 13, 2014 Posts: 119 Location: Natick, MA
Posted: Fri Oct 24, 2014 6:59 am Post subject: removing electric fuel pump |
I am converting the 79 SB I have to carbs for a high performance motor. Can anyone walk me through how to remove the fuel pump, the front electric one, and which fuse and wiring I should remove so I don't have extra wires hanging? |
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Fri Oct 24, 2014 12:02 pm Post subject: |
Why do you want to remove it? Use it and block off the stock pump on the case.
-jeffrey _________________ Der Kleiner Kampfwagens |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Fri Oct 24, 2014 12:31 pm Post subject: |
He would need a regulator to drop the pressure. _________________ Glenn
Member #1009
#BlueSquare |
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Fri Oct 24, 2014 12:43 pm Post subject: |
Electric fuel pump is not stock. So the PO (previous owner) wired it using whatever wire he had hanging around the garage so we don't know what color to look for. He wired it so something hot, probably, but not necessarily to the fuse box. It is probably, but no necessarily the same color as the wire to the fuel pump. And if he were smarter than the average PO he would also run a wire back to the Coil to add a fuel shutoff solenoid.
If he did run a wire to the coil, and even better if he ran it in the wiring harness leave that wire there. If you ever decide to add a tach or a temperature sensor you will already have a wire. |
Posted: Fri Oct 24, 2014 12:44 pm Post subject: |
Refresh my memory, how much pressure does the stock electronic pump put out?
Posted: Fri Oct 24, 2014 12:47 pm Post subject: |
It would have been stock for a '79
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Fri Oct 24, 2014 1:14 pm Post subject: |
28lbs seems to ring a bell compared to 2-3 for Dual carbs.
Injectors need a lot of pressure along with the excess gas returning back into the tank. |
Posted: Fri Oct 24, 2014 4:08 pm Post subject: |
I think you are right, the OP could always remove it and install a Rotary pump in the same place.
Posted: Fri Oct 24, 2014 8:13 pm Post subject: |
Thanks for the responses. I have a brand new motor coming next week which is a 1914cc dual carb setup with a case mounted fuel pump so I need to eliminate the electric one for all of the reasons mentioned above. My thoughts were to leave the wire in place and just remove the fuse in case someone ever wants to put it back to stock, but I'm not able to identify the fuse and wiring clearly from the various Clymer's and other manuals I have been reading. |
wrocek Samba Member
Joined: June 08, 2013 Posts: 397 Location: North Illinois
Posted: Fri Oct 24, 2014 9:38 pm Post subject: |
Another FI engine gone
RIP _________________ 159 2001 678, FI convertible.
AJ 133584*
Made Monday, September 18th, 1978 -> 381-9460 |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Oct 24, 2014 9:41 pm Post subject: |
wrocek wrote: |
RIP |
X2- exactly what I was thinking as I descended the thread... _________________
EverettB wrote: |
FU#5 |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Fri Oct 24, 2014 10:09 pm Post subject: |
DanPorges wrote: |
Silly thing is according to the wiring diagram the fuel pump isnt even on a fused circuit.
maybe put an inline one on the wire where it leaves the relay _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Posted: Sat Oct 25, 2014 6:48 am Post subject: |
wrocek wrote: |
RIP |
Its not gone yet, just wont be in my bug. Its sitting on a stand with a box of FI parts and harnesses next to it. Its for sale! The motor has a burnt #3 exhaust valve, but was otherwise running well....i drove it home from the PO on 3 cylinders. |
