KENNYSILVER Samba Member
Joined: September 20, 2014 Posts: 50 Location: WASHINGTON
Posted: Fri Oct 24, 2014 3:40 pm Post subject: 1970 vw beetle clutch in drum sound throw out? Shocks ? |
I have a 1970 Bug . With the clutch pushed down/engine running . Either at a stop , or rolling - I get a tapping sound . Almost sounds like light backfire but feels mechanical . In the sense that I can feel some mechanical movement . I knocking sound I suppose . The other problem is one I encounter a small bump in the road , On the right rear portion of vehicle , I get a quick snap sound . I don't know if the shock back there is bad . I know , often people think it may be a shock , but many times is something else . Thanks in advance . Any help ? John |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Posted: Fri Oct 24, 2014 8:52 pm Post subject: |
It looks like your Dad got his money's worth out of the Bug . Yeah , I knew it had to be clutch area related . My health has improved so pulling the engine
won't be a big deal . I pulled my first engine around 1983 . I don't know if I even used a jack . John |
Posted: Fri Nov 14, 2014 7:14 pm Post subject: |
I sure did . The two lower engine bolts were finger tight . I could not feel the two top bolts . I removed the shroud . There was a bolt put in backwards with no nut . And the left side had no bolt . I got it all back together and cranked all the fasteners down . Less leak and runs good . And the wipers were out of proper calibration . The Vw repair shop guy wrote on the service ticket "Needs new wiper motor " And a new switch . Maybe they should have just got a new car !!!! Thanks - John |
