grandpa pete Samba Member
Posted: Fri Oct 24, 2014 6:00 pm Post subject: ducting question |
I found this photo and had a couple of questions ;
What purpose is the silver ductwork on the sides of the engine ?
what is the advantage ?
The outlets on my type3 engine is capped off , see black cap below ; will that hurt the engine ?
Where should the small outlet off the air vent go to if I have the same carbs and air vent as above ....
_________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1164 Location: Las Vegas, Nevada
Posted: Fri Oct 24, 2014 11:02 pm Post subject: |
If you have heater boxes then yes you should have the silver air hose or your exhaust will get very hot in the heater boxes and will melt down over time. If you have J tubes then you will be fine to have them capped off but you will want to make a heat shield to shield the heads from the heat off of the exhaust. The oil vent will go to the air cleaner on the right via a hose but if there is no elbow to connect to then run the hose down to the ground. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
