callmeclive Samba Member
Joined: July 26, 2014 Posts: 9 Location: British Columbia
Posted: Fri Oct 24, 2014 10:55 pm Post subject: Newbie - WBX Engine Rebuild - how far do i take it? |
Hey all, I've been trolling for months now.
I recently bought a beater $1300 vanagon tin-top with a camper conversion. It's running on three cylinders.
I've just picked up a 1.9 engine, although the seller doesn't know the state. I'd love to ultimately just stick it in my van and drive, but I know that's not wise.
I realize I need to do some diagnostics and maybe some rebuilding, but I don't want to over do it, or overbuild it. The plan is to stick this one in while I rebuild (properly) the original one in the van.
I have limited tools - in possession of the normals - torque wrenches, some pullers, etc. I don't have anything fancy.
Time and money are precious - and my van is a turd, no matter how much it's polished. Where do you recommend I start with this new (to me) engine? I have no idea.
I see you're all a smart bunch - help? |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Fri Oct 24, 2014 11:12 pm Post subject: |
Quote: |
Time and money are precious - and my van is a turd, |
time? money? if you don't have either... why did you buy it?
sorry.. are you expecting miracle with a turd vanagon?
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Fri Oct 24, 2014 11:31 pm Post subject: |
Cleveland. Take it all the way to Cleveland.
These vans REQUIRE time, money and passion. This is the Golden Triangle of Van Ownership.
Re-evaluate yourself, and decide if you make a wise purchase. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
the joker Samba Member
Posted: Sat Oct 25, 2014 3:21 am Post subject: |
Totally agree
Theses vehicles require extra care and knowledge for happy ownership
Bail now or do it right
They can become a deep money pit / headache
Think it over, do you really want to do this |
insyncro Banned
Posted: Sat Oct 25, 2014 4:36 am Post subject: |
Read into what is being relayed here.
You can't make a cupcake out of a cat turd. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32574 Location: Reading Pennsylvania
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Sat Oct 25, 2014 5:08 am Post subject: |
Bently manuel, fuel lines, compression test/ leak down, tuneup? , in that order |
Posted: Sat Oct 25, 2014 7:36 am Post subject: |
On topic.....
How far to take it?
Pull the heads
Pull the lifers MARK THEM ON POSITION intake #1, exhaust #1 etc, I use baggies, clean cheap, write on with a sharpie.....
Pull the cylinders, MARK THEM TOO! Scratch or center punch ID
Pull the pistons and rods. ALSO MARKED!
Stop, examine rod bearing, all silver and smooth? Stop here, cranks is probably just fine, rods tend to go first.
brass colored or gnarly? Crack the case. New oil pump, crank polish or grind.
New rod bearings, new rings, lap/grind/replace valves or guides or heads as needed.
Gasket set
New hoses, fuel and coolant
Reassemble and go!
Ghia
Vanagon
Beetle
Terry Kay Banned
Posted: Sat Oct 25, 2014 7:59 am Post subject: |
Quite the question, better yet, better answer's than usual--
If your asking this sort of question, I'd get the Van to somebody who could evaluate the current engines condition prior to you making any moves on your own.
Then if it's a wash out--have someone start at the top , and work to the bottom of the extra engine you have.
No point in half assing a reman only to find you screwed up by short cutting the job after all the work is said & done & it fails to run properly.
If your as short on Dracma's as your telling the crew here-- take off the rose colored glasses & bail on what you have got yourself into, and go find yourself a Chevy Van. _________________ T.K. |
devesvws Samba Member
Joined: January 05, 2004 Posts: 1540 Location: madison va
Posted: Sat Oct 25, 2014 10:38 am Post subject: |
Haters.
Thanks for the suggestions, not so much for those judging my character.
Not that I should have to justify my purchase, but I'm aware these things are labours of love. All I'm saying is that this tinner will never be worth 10k+. I didn't buy it to shine it, and I don't have 2k under my pillow to throw at it whenever.
I bought it to chuck a canoe on top, camp under sappy trees, and drive on salty winter roads to nordic resorts. Use and abuse.
I've diagnosed the dead cylinder. It's not a plug or wire, or distributor, or fuel injection.
I have gas in my oil, and oil being burnt. Zero compression. _________________ 1984 TinTop - VanaWhite - She's old and high maintenance. |
Posted: Sat Oct 25, 2014 11:13 am Post subject: |
Engine time |
Posted: Sat Oct 25, 2014 11:15 am Post subject: |
callmeclive wrote: |
Haters.
I have gas in my oil, and oil being burnt. Zero compression. |
Slap a set of rings in it, drive it!
Ghia
Vanagon
Beetle
Posted: Sat Oct 25, 2014 11:40 am Post subject: |
I hope it's that easy. The guy I bought it from (not a brightest star in the sky) described a major knocking on his drive across the country. A mechanic told him to take it off the road immediately. He said it knocked around the entire drive, but since has stopped. He couldn't tell me anything else, but I'm expecting all sorts of Easter treats inside.
Obviously, I want to get that other engine in asap, after checking it out. Hence, this thread for your (already good) advice. _________________ 1984 TinTop - VanaWhite - She's old and high maintenance. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10367 Location: Sunshine Coast B.C.
Posted: Sat Oct 25, 2014 2:43 pm Post subject: Re: Newbie - WBX Engine Rebuild - how far do i take it? |
From what I've read, the 1.9 is reputed as having a very strong bottom end. If the 2.1 is coming out anyways, I'd put the 1.9 in and see what happens. If the 1.9 has any issues above the case halves then deal with it as needed. AFAIK, heads can be R&R'd with engine in place but doing it that way may be more trouble than it's worth. A "wash" if you will. I'm pretty sure you can mix and match parts to run a 1.9 with Digifant.
It would be mostly your time up until the point you pull the trigger on parts. At $1300 you should be able to get back most of that in parts. i.e. if the transaxle had checked out, IMO, that could be $500 right there.
Neil.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Posted: Sat Oct 25, 2014 3:01 pm Post subject: |
the easiest and shortest route... may be not the cheapest depending on the price
look for a good used engine from someone who did a conversion... and do it as swap... no head scratching on what part to go where, tolerance etc...
btw.. be careful when you call us "haters"... we are NOT haters... and you never know when you need us... be cool... |
Posted: Sun Oct 26, 2014 8:06 am Post subject: Re: Newbie - WBX Engine Rebuild - how far do i take it? |
Vanagon Nut wrote: |
From what I've read, the 1.9 is reputed as having a very strong bottom end. If the 2.1 is coming out anyways, I'd put the 1.9 in and see what happens. If the 1.9 has any issues above the case halves then deal with it as needed. |
Thanks Neil,
It's a 1.9 coming out too. Not 2.1.
My plan is to compression test the new one while on the stand. If psi is good, I'll throw it in. Are there any specific diagnostics I can/should do to the heads (without removing them) before installing? I'll pull the valve covers and check the lifters rockers Springs etc. _________________ 1984 TinTop - VanaWhite - She's old and high maintenance. |
Terry Kay Banned
Posted: Sun Oct 26, 2014 8:25 am Post subject: |
Wouldn't it be a bitch to find out that after you had the engine installed that the head seals leak?
Not sure how you'd find that out on the bench--without tearing the heads off prior to installation, and taking a look at the seal & the area's it's sealing.
There isn't a magic wand waving that you could do to verify this. _________________ T.K. |
Posted: Sun Oct 26, 2014 9:25 am Post subject: |
Ok. Pull the heads, look around, and hope there's no worms in the can...
There's going to be worms. I'll take some pictures and chronicle. _________________ 1984 TinTop - VanaWhite - She's old and high maintenance. |
